URSA Tähtikartta - Starmap not work
ursa starmap from android not work version: v1.6
Finland star community starmap
it says:
Something went wrong. Check that google play is enabled on your device and that you’re using an up-to-date version before opening the app. if the problem persist try reinstalling the app.
latest update SFOS is 5.0.0.77
microG is on and ver. 0.3.12.250932
android app support is on
machine: Sony Xperia 10 II
You should list the installed version numbers of the Ursan tähtikartta-app, microG and probably SFOS (“latest” won’t be that helpful after a while).
