In one phone upgrade from latest 4.4.x to 4.5 fails with this error:
[...] sailfish-upgrade-ui[4664]: Distribution upgrade error: Subprocess failed. Error: RPM failed: installing package appsupport-system-privileged-11.0.0.60.28-1.11.1.jolla.armv7hl needs 14MB more space on the /opt filesystem
If I look into /opt then I see that files are only in alien subfolder with this content:
Thanks, @olf
Before starting this thread, I read earlier ones and found that one as well. But I do not know if it does apply to my case - I the phone has degooglified Android layer as it comes from Jolla Store.
Maybe someone from Jolla team would know if this strange file (system.img;5de434f9) has to be in that folder. If not then I could delete it and problem would be solved.
At least this refers to the possibility that system.img;5de434f9 is not needed:
… all phones with a licensed SailfishOS have Alien Dalvik (recently aka “Android App Support”) and this is what the feature request I mentioned was about. The specific use case is different though.
Yeah, “maybe”. But if you do not ask and do not file a bug report (you filed these posts is in the category “general discussion”) no “someone from Jolla team” will reply.
Yes, likely nobody knows for sure, so you may delete it right away. But I would never “advise” to do so, because you are the system administrator of your Linux phone, hence you decide and you have the full responsibility for your actions. But as the file-name is weird, it is definitely not a full system image (too small), it is not even readable (only writeable for root) this file is most definitely garbage.
The more interesting point is, why it was created there: Something went wrong, but what? Maybe this is just a consequence of an earlier error.
Yes, it is usually not there.
You may post the output of devel-su df -h here to see, at which places you have a space issue and how grave it is.
P.S.: In any case, do backup your data before trying to fix this. No backup, no mercy!
I copied system.img;5de434f9 to partition outside / and /opt and continued with upgrade. It ended with an error, but rebooted and called itself after that 4.5.0.21. Looked up the error (this time not enough space on /) and saw that some 200 packages were not upgraded.
As UI did not offer any upgrades, so finished the whole thing with:
ssu re 4.5.0.21
zypper ref
zypper dup
After boot thereafter there were no errors and Android subsystem did its migration. Everything that is needed works currently fine.
