Hi,
Is it still the case that you have to first have only Android 9 on your device before upgrading to SF OS? I notice that in the latest release 4.1.0 is now on level of Android 10 (API level 29).
So when upgrading to SF are we still using the following software binaries:
Software binaries for AOSP Pie (Android 9.0) – Kernel 4.9 – Ganges (latest)
or can we now start to use the Android 10 instead:
Software binaries for AOSP Android 10.0 – Kernel 4.14 – Ganges (latest)
I also checked the instructions on jolla.com website and that still points to downloading the Android 9 software binaries.
Also is the upgrade path still from Android > 3.4.0.24 > 4.01 > 4.1.0 or can you install 4.01 now with Android 9 Software binaries?
