many thanks. We have bay the 50€ for every device (4x), and every device have a separate account. On not device we have activate the android option, all only sailfish native.
sebix asked if you switched Early Access on, through your Jolla account on their website. If you don’t have this, the update will only be available when it is made public.
Had the same problem on my 2nd device, a Sony X10 Single SIM.
This command did also work on it.
edit: The above command worked and downloaded a lot of files for half an hour but after reboot, still SFOS 3.4.0.24 present. (I was typing above post while downloading…)
What can be the reason for this?
edit:
why on the second device ssu re 3.4.0.24
and on the others ssu re 4.0.1.48
only typing error or has this some meaning?
edit:
Update successful: I did the following:
devel-su
ssu re 4.0.1.48
version --dup
reboot.
then:
ssu dr customer-jolla
pkcon refresh
version --dup
While the last command was running, the phone switched off autonomous.
After power on again, while entering the access code the second time, the phone switched to the new blue background.
System info says now: SFOS 4.0.1.48 Koli
Mail accounts still present and working.
Phonebook entries OK
A bit late here. The last example worked fine for me and I’m now on 4.0.1.48.
My problem is, that months ago I downloaded 4.0.1.45 and now, when I check for updates, it tells me to install that one.
I probably just have to delete a file somewhere, but I don’t want to mess with it blindly.
