/home/nemo/.cache/store-client/os-info is shows: downloadSize=installSize=removeSize=-1 .
Interesting: when selecting the correct settings page, for maybe half a second there is a caution sign and some error text. But I cannot read it, because it disappears too quickly.
Changing release from 4.0.1.45 to 4.0.1.45
Your device is now in release mode!
WARNING: DBus call failed, falling back to libssu: Message recipient disconnected from message bus without replying
terminate called after throwing an instance of 'zypp::parser::ParseException'
what(): /etc/zypp/repos.d/ssu_openrepos-Acce_release.repo: Section [openrepos-Acce]: Line 8 contains garbage (no '=' or ':/?|,\' in key)
Abortado
[root@XperiaXA2-DualSIM nemo]# vi /etc/zypp/repos.d/ssu_openrepos-Acce_release.repo
[root@XperiaXA2-DualSIM nemo]# cat /etc/zypp/repos.d/ssu_openrepos-Acce_release.repo
[openrepos-Acce]
name=openrepos-Acce
enabled=1
autorefresh=0
baseurl=plugin:ssu?repo=openrepos-Acce
type=rpm-md
gpgcheck=0
epos-Acce
I recognized that also e.g. Warehouse or pkcon refresh did not work.
I had similar issue at some point. One openrepos repository entry had corrupted in the corresponding file, but I can’t remember the file anymore… I can look it up later.
I removed all openrepos repositories and followed the trouble shooting guide. I can confirm that a reboot is needed after all repos have been removed for a refresh to work. I’m now downloading the latest upgrade.
It was /etc/zypp/repos.d/ssu_openrepos_*_release.repo. Can’t remember the exact file anymore. Check them out, the corruption really stands out. If it is there, that is.
