tomdi
23 October 2022 10:29
1
I got a new to me phone (Xperia 10) where I don’t have the PIN code to unlock Android. (The provided numbers failed so far. What is this PIN code).
Question: is it still possible to install Sailfish X on such a device or is it basically dead weight?
Before spending much time to search the internet for answers, I thought I could ask here. Maybe someone knows this situation. Thank you.
See here:
Sailfish X Installation Instructions - Jolla ,
on the right side there is Xperia 10, there click on the image of your computer OS (Windows, Linux, Mac). There are detailled instructions. Good luck!
tomdi
23 October 2022 11:59
3
Thank you for the reply. Yes I know this page.
What I’m unsure, is
if in this situation I must use the Emma tool to reinstall Android (9) and if I will be able to run Android afterwards?
Or if I can just ignore that I’m unable to login to Android and skip Android testing
Or maybe there are other considerations?
Flash without beeing connected to network is not good
i did it once and had.sfos without well, network
you can flash some android image on your.phone, connect to mobile network and do a.phonecalll …
then flash sfos
Think that you should use Xperia Companion application to reset this pin-locked device, as Emma recognises bootloader unlocked devices for recovery.
tomdi
23 October 2022 15:32
6
Sorry, I don’t quite understand. The phone is unlocked according to the boot message. Does that mean that I can use Emma?
Absolutely, sorry for any confusion here as wasn’t aware already bootloader unlocked.
tomdi
28 November 2022 13:53
9
Installing Sailfish on an Android phone without a PIN was not a problem. Below some notes (basically what you wrote here and the instructions). As I prefer XA2 this “new” “10peria” is for now a spare device.
Reflash for e.g. Jolla Xperia 10
(had issues with volume-up connection as initially one side of the USB cable was already
attached, both ends must be unattached otherwise it won’t go into e.g. ‘blue-LED-state’)
