Hello everyone, on my Xperia XA2 dual sim with Koli, I would like to remove Coderus patchmanager3 that I installed through Storeman, but both from there and from the terminal I can’t, it gives me this error:
Where am I wrong?
You’re not wrong. Uninstall simply fails and does not complete that way.
To help us helping you, as not everyone is able to read messages in Italian, you could have issued an export LC_ALL=C first.
Uninstalling the package fails because it references an uninstall script that does not run at all or not without errors. The package manager then refuses to continue its work.
To circumvent this, you could use rpm to uninstall a package, telling it to not run the uninstall hooks that have been configured in the package itself:
rpm -e --noscripts <packagename>
Please be careful, and good luck.
I would say it worked, thank you!
And sorry if I posted the terminal screen in Italian!
