Android 12 ( 62.1.A.0.617, newflasher) => SFOS (Mobile data ok till self broken) => same android 12 (newflasher) => SFOS
brought the mobile data back in SFOS. It worked fine starting with 1st SFOS boot, survived several reboots. I had no WIFI configured during this time. Then after a while it stopped - see below.
(I mention the sequence because I also tried Android 11 => SFOS (mobile data broken) => Android 11 with EMMA (mobile data ok) => SFOS - but that did not get Mobile data back)
In all cases the phone shows 4G connection, with data “enabled”. The data symbols in the status are ok (they don’t display unless data truly works).
So: after reflashing, it worked ok until rebooting the day after => then back to the repeated Unexpected data call status 4100 from ofonod with no mobile data.
It ceased working a bit before taking off so left it like that => after landing, surprise! It started working just fine once abroad with roaming enabled (4G, Vodafone RO).
At some point it auto switched to Orange RO, worked a while then got stuck in 3G with the same error. I could force it back to Vodafone RO - and it kept working ever since.
I will try to structure a bug report - but aside telling that in some circumstance it reliably breaks itself, I don’t know what to describe. I can provide ofono/system logs as well.
As opposed to other reports:
it works ok starting with boot (while it lasts) with Dual IP (default settings)
Once broken, switching slots, IP setup, etc - won’t help
Hello,
It seems you lost the data after adding the SD card. I forgot to mention that i put the SIM card in slot1 and SDcard while in android mode, and never touched them again.
Also i did not change SIM settings (enable/disable) after getting the data as i saw some weird behavior before: when disabling SIM2, i still have a network icon, (top right of the screen) but no connection at all. If i disable SIM1 and enable SIM2 i do not have any network icon on the top right.
Not sure if it is related, so far not touching anything related to SIM or network, the phone has still data (i can turn the wifi on and off keeping the connection), so i am not making any new experiment.
Tried while in roaming with the phone chosen operator (OrangeRO) => no difference. Hand chosen Vodafone RO works (in either 3g or 4g, with Dual or IP etc)
I can’t test now with “home” network.
I should not have posted this, as this brought bad karma to my phone.
This morning the data connection did not survived reboot, and i was back to initial stage
But i was able to revive it quite easily:
turn on the phone → no data
go to Settings → Pin code: turn off ‘Require PIN code’
reboot
Data is back.
Not sure if this is reproducible, if someone can confirm, it would be appreciated.
Hello Jameson,
Could you please let me know if you are using the SW binaries v8a (from my initial message) or v9a (default from the Sailfish flash script), to understand if it makes a difference?
Also do you have 1 SIM in SIM1 + 1 SDcard on SIM2, or a different config?
Hi i have the same problem while roaming, the status bar shows 4G but there is no real connection. Switching to 3G it actually drops to 2G, hence impossible to check further.
Okay, got something. Its first time im able to make several reboots and mobile data survives.
What i did:
inserted sim card into slot 1
slot 2 empty
flashed 109 Android
flashed sailfish 64 with binaries 8a
after fresh install i started to play with system.
Wifi was all the time disabled
Enabled/Disabled flight mode - success
Disabled/Enabled moblie data - success
Disabled/Enabled slot1/slot2 - success
Changed Protocol IP/IP6/Dual - success
Enabled/Disabled Roaming - success
systemctl stop ofono
rm -rf /var/lib/ofono/*
systemctl start ofono
Had to select Use sim card 1 on mobile data to activate it without reboot as mentoined here https://jolla.zendesk.com/hc/en-us/articles/115011870727-Resetting-oFono-settings-to-make-mobile-data-work
success
(you can omitt these steps, was test purpose what will happen on fresh install to confirm if im able to break it. As result it didnt break it and gave me hope that after reboot shouldn’t also, was true)
Its 4th reboot and i still got mobile data. As i mentoined before i was able to reproduce broken mobile data after every first reboot on Sailfish OS 68 with binaries 9a and not matter if sim card on slot 1/2 with or without sd card.
UPDATE
Mobile data still survives after:
removed sim card for 1 minute, inserted again on slot 1 and rebooted - success
removed sim card, inserted again on slot 1 and sd card on slot 2, rebooted - success
Hello Akikyo,
Thank you for your update, sound promising. Seems your phone is now behaving more or less like mine, so i would like to confirm two items:
are you in an area with 5G coverage when you reboot? (i agree it is difficult to say from Sailfish, but if you have checked before while running Android)
Is you sim card pin locked?
In the case you end up loosing data, could you try the SIM pin unlock to see if it helps recovering data?
First i wanna thank you guys for testing and reflashing.
But tgese tests don’t proof anything. Many people including myself had mobile data working correctly after a reflash. Mine was gone after updating to .68.
To trst your solutions, i think you should reflash at least 3 times and see if it still works using your method.
But if it is working now i wouldn’t risk breaking it by reflashing.
I hope for a fix by Jolla.
Ofcourse you are right, but there left few things to confirm.
I tried several times flashes with 68, even binaries 8a, no luck.
Today i tried with 64 (saw few posts that this update broke) with 8a. So far so good.
I also waiting for fix from Jolla and i dont care if mobile data works right now. What is sense using phone as daily driver not being relaible?
In my case mobile network was working fine from sim1 at home. The network issue i am having is while roaming abroad. Interestingly when i put my card in sim2 slot, network while roaming seems to work fine, i do need my sd card tho.
Sorry i am not getting your point. You are saying data works fine after reflash for most people, so we should test reflashing multiple times to prove the solution is working?
What i achieved today with OS 68 and FW bin v8a is that i was able to recover data connection without reflashing, only by unlocking SIM pin code and rebooting. Since then the data survived enabling/disabling SIM 1 and 2, reboot, or flight mode. I am waiting for the next time i loose data to try the SIM lock trick again but being able to recover data without a reflash is my preferred option.
Sorry, my fault, i thought this was the thread about non working IPv4 connection when using mobile data.
Seems i got confuse by all the threads about mobile data problems using the 10iii.
I did 2 more reflashes. Now with sim card in slot 1 and sd card in slot 2 from the beginning procces, in android. Everything works, swiching between wifi, disabling mobile datas, reboots etc. No I will be using as daily driver, lets see.
To sum up, what worked for me: flash android 109, flash Sailfish OS 4.4.0.64 with v8a binaries. Sim card in slot 1, sd card in slot 2.
Hello Akikyo,
Thanks for sharing. I use a similar configuration daily now and have no data issue so far.
My config:
flash android 109
flash Sailfish 4.4.0.68 with v8a binaries
Sim in slot 1, SD card in slot2
SIM is not pin lock (i am still trying to see if it change something, but had no time to experiment more).
