BUILD ID = OS VERSION (Settings > About product): 4.2.0.21
HARDWARE (XA2, X10, X10 II, …): X10
UI LANGUAGE: Polish
REGRESSION: (compared to previous public release: Yes, No, ?): N/A
Unable to send MMS
have working mms setup - device should be able to receive mms
- go to gallery
- select preloaded image, the one with the camera film
- send it using mms
mms has been sent
mms not sent, from mms logger: MMSC error code 130, I’ve been able to spot on some screen an info for a short period saying: Data to big.
2021-09-29 21:19:14 [mms-ofono] Interface: rmnet_data1
2021-09-29 21:19:14 [mms-connection-nemo] Interface: rmnet_data1
2021-09-29 21:19:14 [mms-ofono] Context /ril_0/context2 is active
2021-09-29 21:19:14 [mms-connection-nemo] Connection 260060016473053 opened
2021-09-29 21:19:14 [mms-dispatcher] 260060016473053 OPEN
2021-09-29 21:19:14 [mms-dispatcher] Send[8] NEED_CONNECTION
2021-09-29 21:19:14 [mms-task-http] MMS interface address 10.193.67.149
2021-09-29 21:19:14 [mms-task-http] MMS proxy 10.10.25.5:8080
2021-09-29 21:19:14 [mms-task-http] /tmp/mms_PSs9ev/mms2021-09-29T211844/msg/8/m-send.req (528320 bytes) → http://10.10.28.164/mms/wapenc → /tmp/mms_PSs9ev/mms2021-09-29T211844/msg/8/m-send.conf
2021-09-29 21:19:14 [mms-transfer-list] Transfer /msg/8/Send started
2021-09-29 21:19:14 [mms-task] Send[8] NEED_CONNECTION → TRANSMITTING
2021-09-29 21:19:14 [mms-transfer-list] Update flags => 0x11
2021-09-29 21:19:14 [mms-ofono] Settings.Netmask: 255.255.255.255
2021-09-29 21:19:16 [mms-task-http] HTTP status 200 [application/vnd.wap.mms-message] 24 byte(s)
2021-09-29 21:19:16 [mms-task] Send[8] TRANSMITTING → DONE
2021-09-29 21:19:16 [mms-transfer-list] Transfer /msg/8/Send finished
2021-09-29 21:19:16 [mms-task-send] ERROR: MMSC responded with 130
2021-09-29 21:19:16 [mms-dispatcher] Send[8] DONE
