REPRODUCIBILITY: Always
BUILD ID = OS VERSION: 4.0.1.48
HARDWARE: Sony Xperia XA2 (Dual SIM)
UI LANGUAGE: German
REGRESSION: I didn’t test this headset on the previous SFOS version.
I am using the “Soundcore Liberty Air 2 Pro” Bluetooth (v5) Headset. I have no issues with the connection and the music playback and also the button controls are working fine.
But unfortunatelly I am unable to switch the audio to this headset during a phone call - the voicecall-ui does not display a button for switching the audio sink device (as it should like described here), this button is shown for another headset but not for this specific one.
Aquire a “Anker Soundcore Liberty Air 2 Pro” headset and pair this device with your XA2 (enable the automatic connection for this headset).
- Turn on your Bluetooth on the XA2
- Turn on the headset (open the case)
- Wait for the automatic connection
- Start a phone call
The voicecall-ui shall display the button to switch the audio from the earpiece to the connected headset.
The voicecall-ui does not display the additional button to switch the audio onto the connected headset.
After the headset is connected and a phone call has been established, the journal log contains the following entries:
[root@Sailfish nemo]# journalctl | grep -e bluetooth -e pulseaudio -e ofono
Mär 13 23:22:03 Sailfish bluetoothd[4223]: bluetoothd[4223]: Can't open input device: No such file or directory (2)
Mär 13 23:22:03 Sailfish bluetoothd[4223]: bluetoothd[4223]: AVRCP: failed to init uinput for Soundcore Liberty Air 2 Pro
Mär 13 23:22:03 Sailfish bluetoothd[4223]: Can't open input device: No such file or directory (2)
Mär 13 23:22:03 Sailfish bluetoothd[4223]: AVRCP: failed to init uinput for Soundcore Liberty Air 2 Pro
Mär 14 00:35:49 Sailfish bluetoothd[4223]: bluetoothd[4223]: /org/bluez/hci0/dev_12_34_56_78_9A_BC/fd11: fd(25) ready
Mär 14 00:35:49 Sailfish bluetoothd[4223]: /org/bluez/hci0/dev_12_34_56_78_9A_BC/fd11: fd(25) ready
Mär 14 00:36:26 Sailfish ofonod[3016]: data reg changed 1 -> 2 (searching), attached 1
Mär 14 00:36:26 Sailfish ofonod[3016]: Deactivating context: 1
Mär 14 00:36:26 Sailfish ofonod[3016]: Clearing active context
Mär 14 00:36:26 Sailfish ofonod[3016]: Deactivated data call
Some device information:
[root@Sailfish nemo]# bluetoothctl
Agent registered
[Soundcore Liberty Air 2 Pro]# devices
Device 12:34:56:78:9A:BC Soundcore Liberty Air 2 Pro
[Soundcore Liberty Air 2 Pro]# info 12:34:56:78:9A:BC
Device 12:34:56:78:9A:BC (public)
Name: Soundcore Liberty Air 2 Pro
Alias: Soundcore Liberty Air 2 Pro
Class: 0x00240404
Icon: audio-card
Paired: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: Serial Port (00001101-xyz)
UUID: Audio Sink (0000110b-xyz)
UUID: A/V Remote Control Target (0000110c-xyz)
UUID: A/V Remote Control (0000110e-xyz)
UUID: Handsfree (0000111e-xyz)
UUID: Vendor specific (66666666-6666-6666-6666-666666666666)
According to the product’s webpage this headset supports the bluetooth profiles AVRCP1.6, A2DP1.3 and HFP1.7.
Could someone please point me to some further ways of debugging?
