Unable to check for a system update wifi at home
REPRODUCIBILITY: everytime
OS VERSION: Tampella 5.0.0.72
HARDWARE: Jolla C2
UI LANGUAGE: english
REGRESSION:
I am unable to check for system update wifi at home although internet connection is without a problem. I can browse internet etc. Wenn I use anothe wifi, i can chceck for system update. This problem i have since buying C2 phone. Thanks.
Thank you for your bug report. Unfortunately, I don’t understand it. Could you complete it?
The template helps you to answer all questions Jolla and other users needs to understand, reproduce and fix the issue.
I solved it. I had to disabled Proxy configuration.
