$ ./run-mic.sh
[10/01 15:49:05] : mic 1.0.2 (Sailfish OS 4.1.0.24 (Kvarken))
Info[10/01 15:49:05] : Retrieving repo metadata:
Info:
Info[10/01 15:49:05] : Retrieving repomd.xml …
Info:
Info[10/01 15:49:05] : Retrieving 70fec09e2e4704d1c675e4daec08df75c192fa57639193da96f8df9c22b1b53c- …
Info[10/01 15:49:05] : filename /var/tmp/mic/cache/adaptation-community-common-oneplus3-/70fec09e2e4704d1c675e4daec08df75c192fa57639193da96f8df9c22b1b53c-primary.xml.gz gunzipped
Info[10/01 15:49:05] : filename is now /var/tmp/mic/cache/adaptation-community-common-oneplus3-/70fec09e2e4704d1c675e4daec08df75c192fa57639193da96f8df9c22b1b53c-primary.xml
Info:
Info[10/01 15:49:06] : Retrieving repomd.xml …
Info:
Info[10/01 15:49:06] : Retrieving 46f48a8760033b80286b7cedf353337ddfd1e4f2330fbade4313f8d9c1673b75- …
Info[10/01 15:49:06] : filename /var/tmp/mic/cache/adaptation-community-oneplus3-/46f48a8760033b80286b7cedf353337ddfd1e4f2330fbade4313f8d9c1673b75-primary.xml.gz gunzipped
Info[10/01 15:49:06] : filename is now /var/tmp/mic/cache/adaptation-community-oneplus3-/46f48a8760033b80286b7cedf353337ddfd1e4f2330fbade4313f8d9c1673b75-primary.xml
Info:
Info[10/01 15:49:06] : Retrieving 1ca42657c5b7890973691f108082bca0186cd2ef229b0284f13b7e2e493ba675- …
Info[10/01 15:49:06] : filename /var/tmp/mic/cache/adaptation-community-oneplus3-/1ca42657c5b7890973691f108082bca0186cd2ef229b0284f13b7e2e493ba675-patterns.xml.gz gunzipped
Info[10/01 15:49:06] : filename is now /var/tmp/mic/cache/adaptation-community-oneplus3-/1ca42657c5b7890973691f108082bca0186cd2ef229b0284f13b7e2e493ba675-patterns.xml
Info:
Info[10/01 15:49:06] : Retrieving 5f00fb63718555ec0f04aac3139833bcc85193fc8cad0ffca53c2a33f7177b67- …
Info[10/01 15:49:06] : filename /var/tmp/mic/cache/adaptation-community-oneplus3-/5f00fb63718555ec0f04aac3139833bcc85193fc8cad0ffca53c2a33f7177b67-group.xml.gz gunzipped
Info[10/01 15:49:06] : filename is now /var/tmp/mic/cache/adaptation-community-oneplus3-/5f00fb63718555ec0f04aac3139833bcc85193fc8cad0ffca53c2a33f7177b67-group.xml
Error [10/01 15:49:07] : URLGrabber error: https://releases.jolla.com/jolla-apps//armv7hl/repodata/repomd.xml - [Errno 14] HTTPS Error 404 - Not Found
Cleaning up project directory and file based variables 00:01
ERROR: Job failed: exit code 1
