On my XA2 terminal output for “dconf write /desktop/sailfish/silica/theme_pixel_ratio 1.4” :
“error: The operation attempted to modify one or more non-writable keys”
Have I done something wrong?
No, you haven’t. The keys are non-writable by default. I forgot about that, my apologies!
To make them writable, edit (I typically use nano - which you can install with “pkcon install nano”):
/etc/dconf/db/vendor.d/locks/silica-configs.txt
and comment both lines with a # so it looks like this:
#/desktop/sailfish/silica/theme_pixel_ratio
#/desktop/sailfish/silica/theme_icon_subdir
Reboot your device then try the edits again.
Unfortunately I’m getting error while executing command. Complains about some missing files. Both XA2 with Pallas-Yllästunturi and Jolla 1 with Nuuksio. Too bad ![]()
Edit: Rebuilding harbour-noto worked fine with XA2 though.
Thanks for the reply @deprecated
I commented the two lines in /etc/dconf/db/vendor.d/locks/silica-configs.txt but i still have the same output from terminal (yes i rebooted before testing
Workaround: clockwork from openrepos.
UI themer had a lot of features, not just changing the icons.
Personally I don’t need to change the icons, I would especially like to change the dpi settings, on sailfish like alien dalvik. And change the number of columns and rows of the launcher.
If someone found a solution … thanks to share it
I uploaded the files from my system, I hope that it is enough to run it
https://filebin.net/bhxvctq7g0mjxtz7
Thanks for sharing! I think harbour-themepacksupport icons are missing. They are in /usr/share/icons/hicolor: 86x86; 108x108; 128x128; 172x172 and 256x256
Here they are: https://filebin.net/t5yqyea91uafc864
Very cool, thank you!
I did the following:
cp into place, chown -R root:root the appropriate dirs, chmod /usr/bin/sailfishos-uithemer to 755, chmod a+x /usr/share/harbour-themepacksupport/*.sh
and it runs! Copied icons just now. Running the dependency install now, so we’ll see how that goes. I’ll update with progress.
Edit: I had to manually install the dependencies, which I pulled from install_dependencies.sh:
pkcon install --allow-reinstall -y sailfish-content-graphics-default-z1.0-base sailfish-content-graphics-default-z1.25-base sailfish-content-graphics-default-z1.5-base sailfish-content-graphics-default-z1.75-base sailfish-content-graphics-default-z2.0-base sailfish-content-graphics-closed-z1.0 sailfish-content-graphics-closed-z1.25 sailfish-content-graphics-closed-z1.5 sailfish-content-graphics-closed-z1.75 sailfish-content-graphics-closed-z2.0
I also did the same for imagemagick:
ssu ar nieldk_obs_arm http://repo.merproject.org/obs/home:/nielnielsen/sailfish_latest_armv7hl/
pkcon repo-set-data nieldk_obs_arm refresh-now true
pkcon install -y ImageMagick libMagickCore libMagickWand
ssu rr nieldk_obs_arm
Then selected ‘I have already installed the dependencies’
The app runs, and themes show up in the list, but I just get the spinning wheel when trying to apply one… nothing ever happens. I’m sure I’m missing something simple, and I’ll keep messing with it.
Edit 2: None of the actions in the app actually work, including something like the “restart homescreen” function. I think there might be something missing, like a systemctl daemon, etc. I’m poking around the scripts now to see what’s referenced, but as it stands it doesn’t do much.
Edit 3: chmod a+x /usr/share/sailfishos-uithemer/scripts/*.sh actually lets “apply theme” work, but still nothing on restarting homescreen, etc. Still picking through the scripts!
That way is how the app ui themer reacted to the 3.4 update. I could use - without problems - themer without the gui. Sadly after a reflash of the os the app was gone from openrepos too.
These could help you:
The patch works with 3.3.0.xx, maybe also with 3.4. and was still being maintained by coderus.
https://openrepos.net/content/coderus/patch-launcher-combined-patch
For SFOS 3 it is essential to use the patch from the web catalog, not from Openrepos.
Works not with 3.4 .
OK, then we will wait for an update.
Soon!
Only two o’s in soon???
Did you succeed or any progress?
Hi Edz, maybe its worth to have a look here:
http://web.archive.org/web/20200901180418/https://github.com/uithemer/sailfishos-uithemer
There you can find “sailfishos-uithemer-2.2.1.tar.gz”.
Thanks @s_mario - but I’m not actually wanting the app, but I’m sure the links will be useful to others
None yet, unfortunately. Still trying!
Is anyone able to compile the app and build an rpm?
