[tutorial] Settings menu Customization
I wanted to change the usual Settings menu Items order.
For example I prefer to have “position” and “bluetooth” upper than “VPN”
The configuration is possible in the /usr/share/jolla-settings/entries folder.
The folder “entries” contains all .json configuration files (one for each item in Settings menu).
In the item .json file there is “order”: XX number. You can change it to have a certain Item upper than others
Example:
item “order” number is “350”, in fact is right below item, whose “order” number is “250”
I think he’s talking about the actual Settings menu.
