After flashing system via fastboot I can’t install anything via pkcon in terminal. And I can’t enable bluetooth
Device:Jolla C2 Vommunity Phone
OS: 5.1
OS: 5.1
A looot of info is missing.
Did you flashed all partitions?
Which instructions did you follow?
Any error in flash procedure?
Can you provide script output?
Did the phone worked before?
What error pkcon gives?
And more.
Until you provide more info I highly doubt that this is a bug.
I hlasged all partition using official tutorial from Sailfish ( Linux + fastboot)
But nevermind after, a few command
devel-su
modprobe -r sprd_wcn
modprobe sprd_wcn
systemctl restart bluetooth
Bluetooth work again, the problem was in 2 virtual devices which system detected as bluetooth ( hci0 and hci1)
Great. What about pkcon?
I don’t need to use pkcon, it’s look like SailfishOS missed some conf and files to grow up bluetooth to work. First I upgraded OS from 5.0 to 5.1 and everything worked, but I play with my app (Debian Dialer 2.0) and I had to add some lines of code in file ofono and in the end I had toreflash whole OS ![]()
Now, bluetooth, and sending sms in my app working ![]()
