Tractive GPS on Sailfish
Hi there,
I am a very new Sailfish user, and I should say first that I have very little technical knowledge. While waiting for the new Jolla phone, I decided to buy a second-hand Xperia XA2 and put Sailfish on it. For my daily life, -almost- everything works perfectly, except that I need the Tractive app to monitor my herd with GPS (I am a shepherd). But I cannot install it on my phone. Does anyone else use this app or has found a way to use it with Sailfish? It is a quite popular one for cats and dogs so let’s hope.
I searched the forum and found nothing.
Thanks!
I could install it but did not get it work on Xperia 10 II. I do not have those devices either. Hopefully you get a solution.
Installs, starts and runs on my XA2 with MicroG.
I created an account, completed the setup wizard, could not enable Bluetooth (yet), got a notification that some features are unavailable.
Edit: I got it to work on the 10 III, too. I had (stupidly) signed up with Google on the XA2, so I had to use Google on the 10 III, too, because I didn’t have a password. It turned out that the app didn’t sign in to Google but instead read that info from the MicroG Settings which I hadn’t configured.
You mean you installed µG separately, or you just enabled “µG services” in AAS settings?
Yes, the old-fashioned way with adding the repo to F-Droid.
I know this is an old topic, but I thought I’d update it with current information.
  • Tested on Jolla Phone 2026 with Android App Support, Tractive version 26.33.0
  • The Android App itself works fine: I can track my dog, update settings, …
  • I couldn’t get bluetooth to work. It tries to “Turn on Bluetooth” and fails. This means that all of the ‘newer’ features such as heart rate tracking, … don’t work.
I don’t quite remember how setting up the tracker out of the box worked but I suspect that Bluetooth is also required for that step.
Thank you, Same here, with new Jolla Phone 2026 everything works fine except the Bluetooth.
I have Tractive working as well, except Bluetooth
I have Tractive working including Bluetooth that is used for the radar. I only have a problem receiving notifications. I want a soudn and a message even if Tractive app has not been started and the screen is locked. Has anybody that working then I would be interested in your setup.
Works fine for our cat. Getting the messages when he leaves the home area or aproaches the road both on the Jp26 and through appsupport onto my garmin watch. I just tested bluetooth, which I had not configured for rhe JP26 yet. Works, but is less sensitive than on the iphone. I have the old version of the band without health functions. At least for me everything seems to work and I have been using it for tracking the cat since I got the phone in August.
