This could be fixed by switching to Opal.Tabs, which would not only fix that issue but also make tabs look consistent with Jolla apps. I’ll try to make a PR with that when I’ll work on the Pixelfed fix.
Took the occasion to revise the translation and finish it ![]()
Announcing version 1.3.3. This version contains fixes for poll views (again) preview cards and updates Italian, Swedish and French translations. Slowly getting all the bugs out.
Up on Release 1.3.3 · poetaster/harbour-tooter · GitHub coming to chum, openrepos and harbour … ping @molan …
Thank you so much for your hard work!
Announcing the release of version 1.3.4 of tooter With many thanks to @roundedrectangle for numerous ui improvements and @frankps for NO translation updates as well as a chimerical italian
up on github, (GitHub - poetaster/harbour-tooter: Tooter is Mastodon client for Sailfish OS. · GitHub) pushed to chum and harbour … @molan maybe you have a chance to push to openrepos? Thanks all
Thanks for great work and update @poetaster , @roundedrectangle and everyone involved
The latest release is on openrepos.
Thanks as always for the great app. Maybe I’m just being dense, but is there an option to hide any of the navigation elements? I run my own solo Mastodon instance, so “Local” and “Trending” in particular are extras that I’d never end up using. Though if there was an option to hide and/or re-order them, I’d personally just be rolling: Home, Notifications, Search, and Federated.
Good question
It’s already in the queue since a number of other instances don’t implement the one or the other endpoint.
Hi, since recently it is no longer possible to tap #keywords to directly search for them - is this intended or a regression?
I would also love to have clickable search history while we are at it ![]()
It’s a regression. Internal links are also broken.
Something is seriously broken in tabview. I’m trying to work around it, but the search function works fine, but attribute bindings in items in the tab just don’t work.
Corrections for search and internal urls are contained in
VERSION 1.3.5 up on github and chum and coming to harbour and openrepos (ie @molan will do us the kindness ![]()
The search facility needs a refactor. But I’ve been suppressing that knowledge for a year ![]()
I think locale server also is broken - it isn’t my home server. Do you check @poetaster ?
There is no locale server. What are you observing?
I do get shown latest toots from my local server (the instance of mastodon whre my account is registered) in the third tab. Seems to work fine
I noticed getting EuropeSays in locale. I think it has to do with small servers using relay functionality.
Tooter seems not to filter out these servers (or messages from relayed servers). The Ivory client on iOS doesn’t have the problem and only shows messages from my home server mastodon.babb.no.
My guess… I’m not sure.
Ah, ok. You mean Local
I thought you were referring to locale’s in the sense of language localization.
There are a coupe of issues here, including that not all servers have the ‘standard’ paths like ‘Home’ or ‘Local’ at all. It’s something I’m looking at.
Already fixed, you are amazing!
What I really miss is a date indicator. All posts show just a time, but not date - makes it difficult to get how old a post is.
