The Volla 22 (Gigaset GS5) Thread
Don’t install this update on a rephone/GS5. Not sure about the Volla 22, but my rephone and GS5 both now exhibit odd behaviour. Don’t recognize usb is plugged (reboot to charge phone) and lose audio when plugging/unplugging 3.5mm jack.
EDIT: And, though this makes no sense, navigation won’t work on 5.0.71 where it’s fine on 5.0.62.
Is it possible to install Sailfish OS on the Gigaset GS5 Pro version? Thanks
Should the “13” be “12”? My GS5 isn’t booting after a successful update of 105 packages - which is an awful lot compared to the same update on the Sonys.
Before I reflash: has the size of the home partition been fixed? Ubuntu Touch uses all available space, not half of it. If not, can I just edit the script?
I just got my GS290 back this week from a friend (a VoLTE specialist; no luck), updated 4.5 → 4.6 → 5.0 with sfos_upgrade. No problems on that one (Kuri worked on all SFOS versions).
hmm, maybe. let me check!
I finally flashed my GS5 (twice but with good results). A fresh install of Kuri works on a freshly flashed 5.0.0.62 but segfaults on a freshly flashed 5.0.0.71-3.
The problem might be just one updated library in /usr/lib64. Any ideas? I previously suspected a qt5/qml problem but that led to finding the fix for Sailfish Weather on 5.1 and 5.2.
On my XA2 (4.5 → 4.6 → 5.0), C2 (5.0 → 5.1) and 10 III (? → 5.1) a working Kuri survived updates.
On my 10 II/5.1 Kuri crashes on the map view in seconds, on Miami/5.0.0.77 and JP2/5.2 Kuri segfaults when started from the command line and complains about missing activities directory, and indeed, the user directories aren’t created in .cache, .config and .local.
Edit: old version is 5.0.0.62.
There is a libc disconnect (annoying) between 5.0 and 5.1. I’m trying to compile as much stuff as possible with 5.0 targets still since my fave phone is still the volla 22. But a number of things I’m forced to go newer. Thankfully not too many.
Which version from where?
Openrepos: The 2023 version 0.5.3 installs and works on 5.0.0.62 and survives Sailfish upgrades to 5.2. Used or at least tested on XA2, 10 III and C2.
My GS5/Volla 22 is still on the flashed 5.0.0.62 on top of Android 12 (which is the other reason I assume the “13” in adaptation-community.ini should be “12” - the other reason was a bricked phone with “13”).
The current 0.6.0 installs and works on 5.2 (10 II, 10 III, JP2) and seems to work on 5.1 (Miami; just tested on the couch for a couple of hours).
New installs on the 5.0.0.7x versions are “effed”, dependency hell either way.
Some things are easy: the partition size is OK, there’s a shedload (or shipload) of free space in /userdata. I created a directory, chowned it to defaultuser and created a symlink in /home/defaultuser. On second thought a good place for music, videos and maps.
