Hello,
Having problem with the following:
Detected Linux
Searching device to flash…
Found H8266, baseband:1311-7920_52.1.A.3.49, bootloader:1310-7079_X_Boot_SDM845_LA2.0.1_Q_207
Found 0 devices:
Incorrect number of devices connected. Make sure there is exactly one device connected in fastboot mode.
I’ve moved it around USB ports and changed leads (using sony supplied), as mentioned on frequent search threads.
Tried a macbook with same effect.
Tried to use a flashtool to install the stockROM and had a error then got myself stuck in a boot loop
New to sailfish, attempting to install tama on an xz2 that previously had a custom ROM(lineageos)
Many thanks!
