The FxTec Pro1 Thread
This thread is for discussing the FxTec Pro1 (qx1000) (not the newer Pro1X qx1050)
Installation Images can be downloaded from Pipelines · sailfishos-porters-ci / t5-ci · GitLab
Issue should be logged at GitHub - sailfish-on-fxtecpro1/droid-config-t5
Does anyone know where I can buy a replacement display that is also delivered to Germany?
Search aliexpress for ‘elephone u pro screen’ should do the trick
Unfortunately, I can’t find anything
https://www.aliexpress.com/item/1005005380851194.html?spm=a2g0o.productlist.main.1.4bd5V0m1V0m1Ac&algo_pvid=7f7b599e-e6ad-44b3-a6d1-78984ad45744&algo_exp_id=7f7b599e-e6ad-44b3-a6d1-78984ad45744-0&pdp_ext_f={"order"%3A"17"%2C"eval"%3A"1"}&pdp_npi=4%40dis!GBP!19.49!19.49!!!24.62!24.62!%40211b680e17443581447128808e87a3!12000032820378896!sea!UK!902165191!X&curPageLogUid=rkv7emxWo03M&utparam-url=scene%3Asearch|query_from%3A ?
I am then told that it cannot be shipped to my country
Hi, I’ve seen the SFOS 4.6 and 5.0 has been released for the Pro1X, will it be the case too for the Pro1 ?
you can try a parcel forwarding service
