The Demise of Noson (Sonos controller) on SFOS
It was with some disappointment that I discovered that the developer of Noson has dropped support for the app on SFOS. This was posted 3 weeks ago.
"no longer maintaining the app for sailfishos
Many pages are now broken since Jolla upgrade to Sailfish 4.0.
As I have no more device even time for maintaining the app for this platform,
the project is deleted from sources on the master branch."
This is, or until SFOS 4.0.x.x was, an outstanding implementation of the Sonos controller.
I recognise that the owner of the project doesn’t have an SFOS phone anymore, but it seems a loss for SFOS that the port has been expunged.
The whole selling point of SFOS apps is that it is Linux and uses QT for apps, so porting and maintenance is supposed to be trivial between linices (is that a word?). Apparently it’s not easy enough and this does not bode well for SFOS.
I am not a programmer for this sort of thing, so I can but lament the loss of an app I use regularly.
Finally, the Jolla store where it is hosted should remove it forthwith because it no longer functions adequately
After some searching, I installed the final version of the Sonos S1 Android app which supported 4.4. However, while it installs, all one gets is a message saying to update to a later version, so the Android route in gone forever as well.
S2 devices such as the Beam while officially supported by later versions of the S1 app, but are unrecognised by the v9.3.2 app.
I would suggest to ask the developer to atleast get the source hosted in Github so that someone can help it fix it in the future.
It have seen somewhere that @piggz previously had involvement in the hosting on OpenRepos. I am guessing that stopped at some point when official support was included in the main development tree and it was hosted on the Jolla Store
Someone such as @piggz clearly has the skills to pick this up, but whether he has the time and or inclination is unknown.
Perhaps he will respond to this ping
ugh, if only he’d asked me for help porting the pages to 4.0. If i find time i will look to fork the last working version with sfos support.
The app has received 40 thumbs up and 100 downloads! That’s a lot of thumbs up for the amount of downloads. Still a niche app with few loyal followers.
Thank you. You are a Gentleman and a Scholar, and we are few that remain :wink:
Code is here https://github.com/janbar/noson-app
Did you have a look or fork it? Just curious. I don’t have the skills to help.
Fixup of old posting of mine on 2021-05-01
… that means, one should branch / “fork” right before this commit:
I.e., at tag 4.4.9, but use the first link (in the box above) to see the diff for the SFOS-eliminating commit!
So, with qt 5.15, bringing back noson isnt that difficult :slight_smile:
Some issues to iron out, but hopefully will be on chum soon
Noson is now available in Chum.
It uses qt-runner to launch the application, if the fonts look too big or stretched, use the qt-runner settings to change the forced DPI. By default, mine was 403, but the application looks much better with 300.
As with noson, it can take some time to find your sonos system, atleast it does here, but it does work.
I just looked through the repo and if I see correctly, it’s just upstream, a desktop file and the spec file. And obs/chum does the rest. That’s pretty bloody cool.
Can’t find it on chum… Does it have another name?
I just ooen chum, browse the packages and there is no package named Noson.
What do I do wrong?
it’s only available for 4.5.0.19
@piggz Are you still maintaining Noson? I recently installed it and I see that it could need some love…
It is drawn up incorrectly:
Other then that it works brilliantly!
Check this reply The Demise of Noson (Sonos controller) on SFOS - #14 by piggz
Yes, I kind of have. I installed Noson from Chum.
  • Close Noson
  • Open Qt Runner
  • Click on Default Settings
  • Enable Override DPI
  • Select 300 (or less)
  • Apply
  • Open Noson
@pherjung Thanks a lot! Setting it to 200 draw up the GUI without errors.
And I learned something about Qt Runner.
