Tankille (Finnish app for fuel prices)
EDIT: Older version 3.9.19 (197) from Aurora Store works. MicroG is needed and turn High-accuracy positioning ON.
Hello.
The app list fuel stations and shows crowd sourced prices for the fuel on a map. Needs location and Google play services to work.
The app launches and I can log in with my email and password. Location works ie. I can list the closest stations to me. I can also search by town or gas station name. I did not try submitting new prices but I could see the most recent ones.
Only borked thing seems to be the map itself. The map seems not to load because I can see only blue background color where it should be. Gas station icons are also missing. When I launch the app on my Sony Android phone, the lower right corner of the map says “Google”.
I contacted the app vendor and received polite response back. They stated that they had looked into allowing the user to choose which map service the would like to use, but it is not in development at the moment. I expressed my interest in native Sailfish OS version and encouraged them to keep looking into the other map service options. Please do the same if you are in the same boat as me!
The app is downloaded from Aurora and is the latest version: 4.10.0 (368). Aurora states on the store page that Google play services are needed for the app.
Any ideas how to go about trying to get the app working on JP2026? I tried tinkering in the MicroG and Appsupport settings but did not see anything especially map releated.
Edit: I downloaded Google Maps from Aurora and it displays the map!? This tells me that this is not MicroG etc. releated but the app itself is just not compatible?
microG provides a Play Services maps implementation backed by MapLibre. Usually works but evidently not in all cases.
Does Google’s own app work through this as well in JP2026? This would mean that Tankille app’s implemention is at fault?
the map part does work for me, but maybe because I Installed SFOS 5.3.0.15 (not released)
Cool! But that is not the latest version… check under Profile and tap the gear icon. Maybe I’ll try downgrading.
oh there is 4.10, I got older version when I had spoofed my phone with another device
I cant even sign-in with the new one at least if I want to use the google account
at least 3.9.19 worked fine
Ah, I was just taking screenshots of the new version for proof. 4.10.0 is correct (368).
I had similar problems when I first installed the app. I was able to log in with my email and pass but after that I crashed on startup. I thought it was because maybe the app couln’t get location info. I didn’t have a SIM on my phone and even though I had WiFi connection, I did not have “High-accuracy positioning” turned ON. I turned this ON and inserted SIM and then the app started working I believe. Well, not fully working but working as described in the first post.
EDIT: I downgraded and it works for me now as well! I’m running the latest SFOS 5.2.0.22.
And it indeed now says “MapLibre” on the lower left corner!
