Tabsview example and the examples projects in general
Hi,
i was looking for an example of TabsView as used in Dialer, but found nothing then to inspect the qml code on phone itself.
the component gallery does not contain it …
can you point me to some github repo that has an example ?
btw. is the component gallery open source ? i mean, can one contribute and add an example ?
btw.
it seems that TabView is part of: Sailfish.Silica.private 1.0
for what good reason is that ?! why private ?
Ok, here goes the example: (for the sake of length i have kicked out the copyright)
import QtQuick 2.0
import Sailfish.Silica 1.0
import Sailfish.Silica.private 1.0
Page  {
    anchors.fill: parent
    TabView {
        header: Column {
            width: parent.width
            TabButtonRow {
                Repeater {
                    model: [
                        qsTrId("tab1"),
                        QsTrId("tab2"),
                        qsTrId("tab3")
                    TabButton {
                        onClicked: tabs.moveTo(model.index)
                        title: modelData
                        tabIndex: model.index
        model: [tab1View, tab2View, tab3View]
        Component {
            TabItem {
                Label {
                    text: "tab1"
        Component {
            TabItem {
                Label {
                    text: "tab2"
        Component {
            TabItem {
                Label {
                    text: "tab3"
One thing to mention:
Most of the time you want to fill the tabs with other components located in other files. in my case i had 4 pages for it (Page). These would not should on UI until i did change them to from Page { … } to SilicaListView {…}
You can use this way from my application. It is not prohibited in official store
thanks, but this is not a tab but a collapsing, grouped list.
in my app i have implemented a corousel, similar to windows metro, where the last swipe would bring you back to first page.
the new tab is behaving the same way, it goes in circle …
so i did switch from my old implementation to the tabview.
I refactored the tab bar used in Piepmatz and Wunderfitz into a stand-alone component. Maybe you would like to use it as long as Silica’s TabBar is still a private component? You can find the code here: https://github.com/ichthyosaurus/sf-docked-tab-bar
(I didn’t have the time for proper documentation yet. You can see here how to use it: https://github.com/ichthyosaurus/harbour-wunderfitz/blob/some-refactoring/qml/harbour-wunderfitz.qml and …/pages/TitlePage.qml)
thanks ! will give it a try
have checked it in piepmatz: looks nice !
Enjoy, it’s dead simple. We will make nice component about it with @ichthyosaurus soon I believe
Hi, brought that in. looks nice ! and works in landscape too :slight_smile:
Nice, glad you like it :)!
Yes, that was a big priority for me; I don’t like apps that restrict the orientation so I try to do better in mine. :slight_smile:
Is still someone planning to release a generic library component of this?
I am currently experimenting with replacing the navigation in podqast: qml/pages/MainCarousel.qml · 445ec8f19a783806b2b4d7ba34374f67377e44b5 · Cy8aer / podqast · GitLab
My implementation is mainly suited for switching qml pages (which are no pages anymore)
There could still go some work into making it more generic regarding tabheader placement
I still.use tabs.in sailkick and will so
in olive i did remove them
i.did use copy paste, a lib build.in chum would be nice …
Necroing this a little bit just in case anyone ends up here while trying to figure out how to do tabs, like I did. The Silica tabs still seem to be private, but Opal’s little-discussed Opal.Tabs component looks just like the first-party thing, and seems to work just fine.
It’s kind of funny that the Sailfish front page promotes that their SDK has tabs, yet the tabs have been private for over half a decade now :squinting_face_with_tongue:
(from https://sailfishos.org)
