For about a year I have had a systemd timer setup to run a shell script daily, based on this stackexchange. It has worked flawlessly until three days ago when it suddenly stopped working, for no obvious reason.
This script is setup to run as root, and the very first thing it does is opening its own log file in /tmp/backup-$$.log. Rebooting the phone does trigger one execution, complete with log entries and correct output. Yet when midnight rolls around there seems to be no attempt for the new day. No traces of any log file in /tmp nor anything relevant at all visible from using journalctl -xn. Running systemctl list-timers now after midnight says the command should NEXT run in “23h”, and lists “n/a” for LAST and PASSED. Output from systemctl status claims the timer is Active (waiting).
I’m on SailfishOS 3.3.0.16 and have been for way longer than since when this issue arrived. No filesystems are full. I mainly use the device for phone calls, barely use any apps and haven’t made any changes to the device for quite a while.
Could there be something which has changed in my SailfishOS system even though I didn’t recently do an upgrade? Are there any packages or patches, which could cause a regression like this, being rolled out between releases?
Any ideas to understanding what might have happened, or how to resume functionality would be appreciated.
Thanks,
