I wake up late because Alarm Clock didn’t alarm! So started to digging around and noticed that almost any native app doesn’t start, suprisingly android apps starts…
I tried to start Clock, Calendar, Email, Phone… none of them starts, circle just runs some times add then app just disappear. So system is some kind of “hung” state. I have restarted phone about 2-3 days ago but now wanted to do some discover before another restart (because that usually makes this thing working again).
Before this issue, I updated some apps via Aurora Store, I put them updating late at last evening and this morning phone is in this state…
Here is snipped grapped from journalctl -f, at least I notice it tries to start “alarm ui” but something happens:
ov 23 08:00:49 JollaPhone2026 dbus-daemon[3527]: dbus-daemon[3527]: [session uid=100000 pid=3527] Successfully activated service 'com.nokia.voland'
Nov 23 08:00:49 JollaPhone2026 systemd[3514]: Started Alarm ui.
Nov 23 08:00:49 JollaPhone2026 kernel: [wdk-c] cpu=3 o_k=3 lbit=0xba cbit=0xff,45,7,1,1217205925,ff,16484584,742880,16484657,742987,[20132935525751,14966023] 29 ffffffff
Nov 23 08:00:49 JollaPhone2026 kernel: CPU:3 CNTCV_CTL:1 CNTCV_TVAL:92f5 CNTVCT:b808624ea4 SYST_CNTCR:1c490d SYST_DISTL:0 SYST_CNTCV:b808624e9f sc:20132900499213
Nov 23 08:00:49 JollaPhone2026 mce[1996]: tklock.c: tklock_datapipe_uiexception_type_cb(): uiexception_type = linger -> alarm
Nov 23 08:00:49 JollaPhone2026 kernel: [wdk-c] cpu=6 o_k=6 lbit=0xfa cbit=0xff,5,7,1,1217205925,ff,16484584,742880,16484657,742987,[20132941682905,14959037] 29 ffffffff
Nov 23 08:00:49 JollaPhone2026 kernel: CPU:6 CNTCV_CTL:1 CNTCV_TVAL:137c2e CNTVCT:b808625534 SYST_CNTCR:1c490d SYST_DISTL:0 SYST_CNTCV:b80862552f sc:20132900627828
Nov 23 08:00:49 JollaPhone2026 kernel: [IPI][TASK_Q] process_message_in_queue(), wait ack, task: 32, msg_id: 0x10, ack_type: 1, p1: 0x0, p2: 0x0
Nov 23 08:00:49 JollaPhone2026 start-jolla-alarm-ui[15864]: gralloc-mapper is missing
Nov 23 08:00:49 JollaPhone2026 kernel: [wdk-c] cpu=2 o_k=2 lbit=0xfe cbit=0xff,1,7,1,1217205925,ff,16484584,742880,16484657,742987,[20132959345367,14942060] 29 ffffffff
Nov 23 08:00:49 JollaPhone2026 kernel: CPU:2 CNTCV_CTL:1 CNTCV_TVAL:242b CNTVCT:b80862511b SYST_CNTCR:1c490d SYST_DISTL:0 SYST_CNTCV:b808625117 sc:20132900546982
Nov 23 08:00:49 JollaPhone2026 kernel: [wdk-k] cpu=0 o_k=0 lbit=0xff cbit=0xff,0,7,1,1217205925,ff,16484584,742880,16484657,742987,[20132967605674,14934305] 29 ffffffff
Nov 23 08:00:49 JollaPhone2026 kernel: [thread:181] 2026-11-23 06:00:49.064428 UTC;android time 2026-11-23 06:00:49.064428
Nov 23 08:00:49 JollaPhone2026 kernel: CPU:0 CNTCV_CTL:1 CNTCV_TVAL:96e CNTVCT:b808625108 SYST_CNTCR:1c490d SYST_DISTL:0 SYST_CNTCV:b808625103 sc:20132900545443
Nov 23 08:00:49 JollaPhone2026 kernel: mtk_dsp_check_exception() deep state[1]
Nov 23 08:00:49 JollaPhone2026 kernel: [IPI][TASK_Q] process_message_in_queue(), wait 10 x 2 ms, retval 0
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mt6858_fe_trigger(), DL_24CH cmd 0, irq_id 12, is_afe_need_triggered 0, no_period_wakeup 1
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mt6858_fe_trigger(), VUL3 cmd 0, irq_id 16, is_afe_need_triggered 0, no_period_wakeup 1
Nov 23 08:00:49 JollaPhone2026 kernel: mtk_dsp_pcm_close() playback
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mtk_afe_fe_hw_free(), VUL3, use_adsp_share_mem 1, using_sram 1, use_dram_only 0, dma_addr 0x0000000011062000, dma_area 0000000086233a49, dma_bytes 0x2000, vow_barge_in_enable 0, trigger close memif pid 3694, tid 3640, name writer and hw free pid 3694, tid 3640, name writer
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mtk_audio_sram_free(), user 000000000fb6ad92
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw882xx_mute: mute state=1
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw882xx_mute: capture
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw882xx_mute: mute state=1
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw882xx_mute: capture
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw882xx_shutdown: stream capture
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw882xx_shutdown: stream capture
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mtk_afe_fe_hw_free(), DL_24CH, use_adsp_share_mem 1, using_sram 1, use_dram_only 0, dma_addr 0x0000000011060000, dma_area 0000000022e0e0fa, dma_bytes 0x2000, vow_barge_in_enable 0, trigger close memif pid 3694, tid 3640, name writer and hw free pid 3694, tid 3640, name writer
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mtk_audio_sram_free(), user 0000000006fe0f09
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw882xx_monitor_stop: enter
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw882xx_dev_clear_int_status: done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw882xx_dev_set_intmask: done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw_dev_switch: btn uls humte set 1 done
Nov 23 08:00:49 JollaPhone2026 mce[1996]: tklock.c: tklock_datapipe_uiexception_type_cb(): uiexception_type = alarm -> linger
Nov 23 08:00:49 JollaPhone2026 dbus-daemon[3527]: dbus-daemon[3527]: [session uid=100000 pid=3527] Activating via systemd: service name='com.nokia.voland' unit='jolla-alarm-ui.service' requested by ':1.3' (uid=100000 pid=3526 comm="/usr/bin/timed --systemd" label="u:r:kernel:s0")
Nov 23 08:00:49 JollaPhone2026 /usr/libexec/mapplauncherd/booster-silica-qt5[3768]: warning: boosted process (pid=15836) signal(Aborted)
Nov 23 08:00:49 JollaPhone2026 systemd[1]: Starting Atlantic: reclaim leaked driver-pool memory (vendor kernel shrinker bug)...
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw882xx_dev_mute: done
Nov 23 08:00:49 JollaPhone2026 systemd[3514]: Starting Alarm ui...
Nov 23 08:00:49 JollaPhone2026 systemd[1]: Started Atlantic: reclaim leaked driver-pool memory (vendor kernel shrinker bug).
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw_dev_switch: btn amppd set 1 done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw_dev_switch: btn pwd set 1 done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw882xx_device_stop: done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw882xx_monitor_stop: enter
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw882xx_dev_clear_int_status: done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw882xx_dev_set_intmask: done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw_dev_switch: btn uls humte set 1 done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw882xx_dev_mute: done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw_dev_switch: btn amppd set 1 done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw_dev_switch: btn pwd set 1 done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw882xx_device_stop: done
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0035]aw882xx_shutdown: stream playback
Nov 23 08:00:49 JollaPhone2026 kernel: [Awinic][12-0034]aw882xx_shutdown: stream playback
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mtk_i2s_en_event(), name I2SIN1_GPIO, event 0x8
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mtk_i2s_en_event(), name I2SOUT1_GPIO, event 0x8
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mtk_apll_event(), name APLL2, event 0x8
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mt6858_afe_runtime_suspend() ready to stop
Nov 23 08:00:49 JollaPhone2026 kernel: mt6858-audio 11050000.mt6858-afe-pcm: mt6858_afe_runtime_suspend: Is going to suspend.
Nov 23 08:00:49 JollaPhone2026 kernel: [IPI][DSP_Q] dsp_send_msg_to_dsp(), pass, task: 32, msg_id: 0x16, ack_type: 1, p1: 0x0, p2: 0x0
Nov 23 08:00:49 JollaPhone2026 kernel: [IPI][DSP_Q] dsp_send_msg_to_dsp(), pass, task: 47, msg_id: 0xadd1, ack_type: 1, p1: 0x20, p2: 0x0
Nov 23 08:00:49 JollaPhone2026 kernel: mtk_dsp_pcm_close() deep
Nov 23 08:00:49 JollaPhone2026 kernel: [IPI][DSP_Q] dsp_send_msg_to_dsp(), pass, task: 47, msg_id: 0xadd1, ack_type: 1, p1: 0xd, p2: 0x0
Nov 23 08:00:49 JollaPhone2026 kernel: [IPI][DSP_Q] dsp_send_msg_to_dsp(), pass, task: 47, msg_id: 0xadd1, ack_type: 1, p1: 0x8, p2: 0x0
Any Ideas, is there any other way to recover than just rebooting phone? I just want to know why this happens and maybe help devs to fix this, its not very nice that you can’t trust your phone works next morning :\
I have installed available 5.2.x SFOS (Finlayson), installed all released patches etc, unfortunately can’t confirm right now which version exactly because settings app doesn’t start…
