REPRODUCIBILITY: Not tested
OS VERSION: 5.0.0.68
HARDWARE: Xperia XA2 (H4113)
UI LANGUAGE: French
REGRESSION:
First time using SailfishOS. I was following the introductory tutorial and I got stuck when I was requested to press on the clock. At that step, the software just displayed the applications screen (bottom screen) and the overlay text saying to press on the clock. There were no area highlighted where to press and no action had any effect. My only solution: wait the battery to deplete to restart the phone (even power button had no effect). When I restarted, the home screen never loaded (stays orange spinner).
Just start the tutorial application at first startup
Maybe play with phone orientation?
Not being stuck. Give the user a way to close the tutorial application?
Do you know about force power down power + volume down on xa2? Also the tutorial can be skipped by tapping the corners, i think clock wise
Thank you for the quick response! I should have check forum before and requested for help when I had the problem.
No, I did not know such solutions… I tried some buttons combination, but probably incorrectly, since I did not know what to do.
I would propose to add an additional tutorial page at the beginning to tell the user: you can quit the tutorial at anytime, here is how (even if tapping the corners in some particular order is pretty complicated for a user that is new and want to follow the tutorial).
Thank you for the hint, something a bit strange is that “power + volume down” did not work to force power down on my XA2.
I had to long-press “power + volume up” instead (info found in [Release notes] Pispala 5.1.0.11 - #35 by amaretzek), so for anyone having the same issue with the tutorial it may be useful to test both combinations (and also tapping the corners, although it didn’t work for me).
