I would recommend putting it on your arm in one of these small bags for running. I once had an xa2 attached to the bike by rubber and since it has no springsi guess a shock detached the flash memory and since that it doesn’t boot anymore. Sony tells me they haven’t got any spare parts for it, even though it was still under warranty. Not even paying for the repair was an option since they apparently really don’t have any spare parts anymore
Bluetooth maybe? I had this problem on the XA2 when the covid app was running and there where many other Bluetooth devices within vicinity (e.g. in shopping malls or on crowded streets).
Don’t know if people use Covid apps in France too.
But afaik journal is cleared after a reboot, so you’d have to be able to look at it after the freeze happens. Maybe ssh into the phone.
Or, change the storage type in /etc/systemd/journald.conf beforehand - have a look here - but I have not tried that.
I’m back. It was a little bit difficult to get a pertinent sequence in journalctl.
Then, I get this strange sequence in journalctl (many many lines like this ones) when my XA2 froze If somebody understand something…
juin 29 10:08:33 Sailfish mce[2261]: tklock.c: tklock_dbus_notification_end_cb(): notification end from name=:1.79 owner=:1.79 pid=4488 uid=100000 gid=99
9 priv=1 cmd=/usr/bin/lipstick -plugin evdevtouch -plugin evdevmouse -plugin
juin 29 10:08:33 Sailfish lipstick[4488]: [D] unknown:0 - sleepDisplay
juin 29 10:08:34 Sailfish kernel: [synaptics][info] synaptics_rmi4_suspend: synaptics suspend +++
juin 29 10:08:34 Sailfish kernel: [synaptics][info] synaptics_rmi4_suspend: synaptics suspend ---
juin 29 10:08:34 Sailfish kernel: mdss_dsi_panel_off: ctrl=ffffffe171148018 ndx=0
juin 29 10:08:34 Sailfish kernel: incell_touch_pinctrl_set_state: invalid 'mdss_touch_suspend' pinstate
juin 29 10:08:34 Sailfish kernel: @@@@ panel power off @@@@
juin 29 10:08:34 Sailfish mce[2261]: modules/display.c: mdy_display_state_enter(): current display state = OFF
juin 29 10:08:34 Sailfish rmt_storage:INFO:rmt_storage_rw_iovec_cb: Write iovec request received for /boot/modem_fs2
juin 29 10:08:34 Sailfish rmt_storage:INFO:rmt_storage_client_thread: Calling Write [offset=0, size=2097152]for /boot/modem_fs2!
juin 29 10:08:34 Sailfish rmt_storage:INFO:rmt_storage_client_thread: Done Write (bytes = 2097152) for /boot/modem_fs2!
juin 29 10:08:35 Sailfish mce[2261]: powerkey.c: pwrkey_datapipe_keypress_event_cb(): powerkey pressed
juin 29 10:08:35 Sailfish mce[2261]: tklock.c: mce_tklock_unblank(): display state req: ON
juin 29 10:08:35 Sailfish mce[2261]: modules/display.c: mdy_display_state_leave(): current display state = POWER_UP
juin 29 10:08:35 Sailfish mce[2261]: powerkey.c: pwrkey_datapipe_keypress_event_cb(): powerkey released
juin 29 10:08:35 Sailfish kernel: incell_touch_pinctrl_set_state: invalid 'mdss_touch_active' pinstate
juin 29 10:08:35 Sailfish kernel: @@@@ panel power on @@@@
juin 29 10:08:35 Sailfish kernel: mdss_dsi_panel_on: ctrl=ffffffe171148018 ndx=0
juin 29 10:08:35 Sailfish kernel: [synaptics][info] synaptics_rmi4_resume: synaptics resume +++
juin 29 10:08:35 Sailfish kernel: [synaptics][info] synaptics_rmi4_resume: synaptics resume ---
juin 29 10:08:35 Sailfish lipstick[4488]: [D] unknown:0 - unsleepDisplay
juin 29 10:08:35 Sailfish kernel: [synaptics][info] synaptics_rmi4_irq_enable: Interrupt already enabled
juin 29 10:08:36 Sailfish mce[2261]: modules/display.c: mdy_display_state_enter(): current display state = ON
juin 29 10:08:36 Sailfish droid-hal-init: processing action (ril.ecclist1=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:10)
juin 29 10:08:36 Sailfish droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
juin 29 10:08:37 Sailfish kernel: [synaptics][info] synaptics_rmi4_sensor_report: spontaneous reset detected
juin 29 10:08:37 Sailfish mce[2261]: tklock.c: tklock_dbus_notification_end_cb(): notification end from name=:1.79 owner=:1.79 pid=4488 uid=100000 gid=99
juin 29 10:08:39 Sailfish mce[2261]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: OPEN -> UNDEF
juin 29 10:08:40 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 279
juin 29 10:08:40 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 280
juin 29 10:08:41 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 281
juin 29 10:08:41 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 282
juin 29 10:08:42 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 283
juin 29 10:08:42 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 284
juin 29 10:08:43 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 285
juin 29 10:08:43 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 286
juin 29 10:08:43 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 287
juin 29 10:08:43 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 288
juin 29 10:08:43 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 289
juin 29 10:08:43 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 290
juin 29 10:08:44 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 291
juin 29 10:08:44 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 292
juin 29 10:08:44 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 293
juin 29 10:08:44 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 294
juin 29 10:08:45 Sailfish lipstick[4488]: [W] unknown:0 - Effect failed, id 295
juin 29 10:08:51 Sailfish kernel: binder: undelivered transaction 9615836
juin 29 10:08:52 Sailfish kernel: PMI: smblib_get_apsd_result: APSD not done yet.
juin 29 10:09:17 Sailfish dbus-daemon[2301]: [system] Connection ":1.79" is not allowed to add more match rules (increase limits in configuration file if
required; max_match_rules_per_connection=512)
juin 29 10:09:17 Sailfish dbus-daemon[2301]: dbus-daemon[2301]: [system] Connection ":1.79" is not allowed to add more match rules (increase limits in configuration file if requ
--------------- and then -------------------
juin 29 10:09:47 Sailfish kernel: PMI: smblib_get_apsd_result: APSD not done yet.
juin 29 10:09:47 Sailfish mce[2261]: modules/battery-udev.c: mcebat_update(): battery_level : 37 → 36
juin 29 10:09:48 Sailfish systemd-journald[691]: Suppressed 349 messages from dbus.service
juin 29 10:09:48 Sailfish dbus-daemon[2301]: [system] Connection “:1.79” is not allowed to add more match rules (increase limits in configuration file if
juin 29 10:09:48 Sailfish dbus-daemon[2301]: dbus-daemon[2301]: [system] Connection “:1.79” is not allowed to add more match rules (increase limits in configuration file if requ
-------------- and then… (many many lines like this) ----------------
juin 29 10:11:14 Sailfish dbus-daemon[2301]: dbus-daemon[2301]: [system] Connection ":1.41" is not allowed to add more match rules (increase limits in configuration file if requ
juin 29 10:11:14 Sailfish dbus-daemon[2301]: [system] Connection ":1.41" is not allowed to add more match rules (increase limits in configuration file if
juin 29 10:11:14 Sailfish dbus-daemon[2301]: [system] Connection ":1.2240" is not allowed to add more match rules (increase limits in configuration file
if required; max_match_rules_per_connection=512)
juin 29 10:11:14 Sailfish dbus-daemon[2301]: dbus-daemon[2301]: [system] Connection ":1.2240" is not allowed to add more match rules (increase limits in configuration file if re
juin 29 10:11:14 Sailfish dbus-daemon[2301]: [system] Connection ":1.1506" is not allowed to add more match rules (increase limits in configuration file
juin 29 10:11:14 Sailfish dbus-daemon[2301]: dbus-daemon[2301]: [system] Connection ":1.1506" is not allowed to add more match rules (increase limits in configuration file if re
