Has anyone else running into problem that on current version installing obb utilizing Android apps does not work? I mean when I install a obb requiring (that worked before on older version of Sailfish) Android app and put obb file(s) on correct “android_storage/Android/obb/” directories they won’t start. Simply stuck on loading or black screen. Older Android apps installed before update that use obb do work correctly. So problem seems to be apps not installing correctly on AlienDalvik.
Also, is it normal not to be able to see contents of obb folder outside AlienDalvik? This has been going on for a while, but I’ve used X-plore for Android to manipulate obb directory instead of native file manager.
Would reinstalling whole AlienDalvik fix this or what?
Edit:
Device I’m using is Sony Xperia 10, flashed from Android9 to official paid Sailfish.
i guess i can’t play x-plane on sailfishos. Has anyone of you tried x-plane on sailfish os?
