since an update of WhatsApp last Saturday morning, I have the following problem: I can receive the messages, but it is impossible to send messages. I tried with two different persons, and after two other updates, there is no change. Did you have the same problem, or do you have a clue about it ?
Phone: XPeria 10 III, Sailfish 5.0.0.76, Aurorastore
Edit: there is no difference between 4G connection and a wifi connection.
Which WhatsApp version do you have now? I have version 2.26.22.8 (Beta), and it runs on my Xperia 10 III (SFOS 5.0.0.77) and it works. I think my version is from Aptoide not from Aurora Store.
I have exactly the same issue.
Have actually had on multipe devices, in the past ~15 months id say. Especially in group chats it shows.
The next thing is then the downloads not starting/completing. Anyone else had those yet?
Sometimes I uded this as 2. app but now it work not more. Maybe we should work on it or contact the developer. Its only a web viewer and you need one phone with WA.
If I start the native App sailfish-qml harbour-whatsapp in terminal I get this under 5.0.0.77. I remember me, that this works under SFOS4.xx in 2025.
library "libui_compat_layer.so" not found
library "libutils.so" not found
library "libcutils.so" not found
library "libhardware.so" not found
library "android.hardware.graphics.mapper@2.0.so" not found
library "android.hardware.graphics.mapper@2.1.so" not found
library "android.hardware.graphics.mapper@3.0.so" not found
library "android.hardware.graphics.mapper@4.0.so" not found
library "libc++.so" not found
library "libhidlbase.so" not found
library "libgralloctypes.so" not found
library "android.hardware.graphics.common@1.2.so" not found
library "libion.so" not found
library "libz.so" not found
library "libhidlmemory.so" not found
library "android.hidl.memory@1.0.so" not found
library "vendor.qti.qspmhal@1.0.so" not found
[D] unknown:0 - Got library name: "/usr/lib64/qt5/qml/io/thp/pyotherside/libpyothersideplugin.so"
[W] NemoConfigurationValuePlugin::registerTypes:52 - org.nemomobile.configuration import is deprecated. Suggest migrating to Nemo.Configuration
[W] unknown:0 - "Failed to attach key memory region for qtcontacts-sqlite-np: QSharedMemory::attach (shmget): doesn't exist"
[W] unknown:0 - "Failed to open contacts transient store"
[W] unknown:0 - "Unable to open synchronous engine database connection"
[W] unknown:0 - QSqlQuery::prepare: database not open
[W] unknown:0 - "Failed to prepare distinct display label group selection query: \n SELECT DISTINCT DisplayLabelGroup FROM DisplayLabels ORDER BY DisplayLabelGroupSortOrder ASC"
[W] unknown:134 - file:///usr/lib64/qt5/qml/Sailfish/Silica/PullDownMenu.qml:134: ReferenceError: lipstickSettings is not defined
[D] unknown:0 - Starting favorites query at 171 ms
[D] unknown:0 - Favorites queried in 239 ms
[D] unknown:0 - Starting metadata query at 380 ms
[D] unknown:0 - All queried in 384 ms
[D] :27 - Backend ready
No, I do not remember the version. The problem is sill here and the different updates of WhatsApp did not change anything. A few days ago, I uninstalled WhatsApp without erasing the personal data (approximately 4 Gb) but it did not resolve the problem.
Some weeks ago WhatsApp enforced an update, so I updated the app to 2.26.29.73 via Aurora Store. The app is still functioning as before without any issues.
Maybe your issues are related to your network setup, or some modifications to AAS (microG)?
Now, I use the version 1.26.36.2 (beta) installed with Aptoide, and the problem is still here. MicroG is not installed in my phone. About the connection, I don’t see where is the problem, because there is no change between 4G, 5G and Wifi. It is impossible to send a simple text message, but a video call with a group works perfectly.
I had similar problems some time ago. I started to receive lot of red errors with exclamation marks when trying to send direct or group messages. I thought I was banned in some way. I never got to know what caused that. Lately I have used WhatsApp, only occasionally, on an Android phone without problems.
