Storeman very slow
Hi.
Recently, I realized that installing or uninstalling applications on Storeman was very slow.
And by slow, I mean it could take hours.
If it was only an install that was slow, maybe the connection could be the problem, but it’s also very slow to uninstall an app.
Does any of you have this problem as well?
Anything I can do to make these operations go faster?
I use SailfishOS 4.3.0.12 on a Sony Xperia XA2.
Thanks.
You can try to use the pkcon command to install/remove packages within the terminal app. If it’s fast enough then the problem relates Storeman.
installation not, but to recognize if an update is pending or enable install menu item takes sometimes …
