Storage space displayed incorrectly
REPRODUCIBILITY: always
OS VERSION: 5.1.0.11
HARDWARE: Xperia 10 III
UI LANGUAGE: English
REGRESSION: new
In Settings > Storage > User data, Android app data is stated as 8,388,608.0 TB, which is obviously incorrect.
None
  1. Open Settings
  2. Select User data
The correct amount of storage used should be shown.
An obviously incorrect and physically impossible usage is shown.
None. Android apps installed are WhatsApp, Threema, Signal and Sdui only.
cf. screenshot.
As I have the same device running the same SFOS version, I checked out what mine shows – I don’t have this error.
I just received my Jolla 2026 (:partying_face: ) and while browsing the settings I also see weird numbers: the total used show far more (11.3GB) than the actual few MB visible in the list below:
But it’s actually the same in the terminal:
$ df -h .
Filesystem                Size      Used Available Use% Mounted on
/dev/mapper/luks-0f7d8d6b-a491-4aa5-a797-68c420523633
218.0G    182.3M    206.7G   0% /home
