Starting VPN clears contextkit key values
BUILD ID = OS VERSION (Settings > About product): 4.3.0.12
HARDWARE (XA2, X10, X10 II, …): XA2 Plus Dual SIM
UI LANGUAGE:en_GB
REGRESSION: (compared to previous public release: Yes, No, ?): Probably not
As soon as I activate VPN, keys like Internet.NetworkType and Internet.NetworkState (provided by org.freedesktop.contextkit) become empty, no longer containing values like “WLAN” and “connected”. I can’t imagine this is by design, as I am still connected to Internet and using my WLAN or GPRS connection and the connectivity itself is fine. I am facing this in my app WelkWeer | OpenRepos.net — Community Repository System for example, which checks for an internet connection this way.
VPN active
  1. Start VPN connection
  2. Check for contextkit key values, WelkWeer | OpenRepos.net — Community Repository System can be a testcase (Dutch “geen internet connectie” popup message at start, without VPN no error message displayed)
Keys like Internet.NetworkState should return “connected”, not an empty value
Networkstate of networktype info is no longer available
I am (successfully) connecting to an OpenVPN server located at my home, tested using wireless and cellular.
Unfortunately not fixed in the 4.4 release.
This appears to be a regression compared to SFOS 3.4.0.24. On 3.4, the values don’t change at all when connecting to a VPN.
(I cannot test it on 4.x or with a mobile connection.)
EDIT: System.WlanEnabled and System.InternetEnabled always stay false, though.
Thanks for the report @adekker, and the additional info @ichthyosaurus. I’ve created an internal bug about this and tagged it as “tracked”.
Sorry that it has taken so long to address the issue but this change takes care of this reported issue and is going to be part of next release.
Great, can’t wait to test it and mark this as resolved!
With SFOS 4.6 now installed I can confirm this issue is fixed.
