BUILD ID = OS VERSION (Settings > About product): 4.1.0.24
HARDWARE (XA2, X10, X10 II, …): Xperia Tama; probably generic OS issue
UI LANGUAGE: -
REGRESSION: (compared to previous public release: Yes, No, ?): Don’t know
While adding ssu features (ini files under /usr/share/ssu/features.d/) adds new repositories as expected, removal of the files from there keeps repositories defined. This is due to the remaining definition in /var/cache/ssu.
- add feature file under
/usr/share/ssu/features.d/. For example, community-adaptation/adaptation-community-common.testing.ini at hybris-10 · sailfishos-sony-tama/community-adaptation · GitHub - run
ssu ur- repository will be listed when usingssu lrand used withzypper ref. So far, so good - Remove the feature file
- Run
ssu ur - Repository is still listed with
After removal and update of ssu, repository should not be used
Repository is still defined and used by package managers after removal.
To remove repository, we have to manually edit a file in /var/cache/ssu.
