Thanks very much @avhakola !
Reviewed version of tweak list for SFOS 5.0.0.68 / Xperia 10
For making backups of original files before changing the values, please use the list from post #70.
Details with commands to c+p:
Values after // are the original value and values from older experiments.
vi /etc/connman/main.conf
Changes the IP-Network range of Access Point - optional if wanted:
12 TetheringSubnetBlock = 192.168.4.0 example
(yet implemented by default, but check) Add ",ifb" here, for better dnsmasq compatibility and DHCP Server:
4 NetworkInterfaceBlacklist = p2p,usb,rmnet,rev_rmnet,ifb
vi /usr/lib/maliit/plugins/jolla-keyboard.qml
Undo:
cp /usr/lib/maliit/plugins/jolla-keyboard.qml.bak /usr/lib/maliit/plugins/jolla-keyboard.qml
646 duration: 100 //300
668 PauseAnimation { duration: 67 } //200
674 duration: 67 //200
/usr/lib/qt5/qml/Sailfish/Silica/ :
Lazy Swipes:
/usr/lib/qt5/qml/Sailfish/Lipstick/*
vi /usr/lib/qt5/qml/Sailfish/Lipstick/ShutDownItem.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Lipstick/ShutDownItem.qml.bak /usr/lib/qt5/qml/Sailfish/Lipstick/ShutDownItem.qml
24 duration: 250 //1000
/usr/lib/qt5/qml/Sailfish/Silica/*------------------------------------
vi /usr/lib/qt5/qml/Sailfish/Silica/AddAnimation.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/AddAnimation.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/AddAnimation.qml
39 duration: 10 //150
vi /usr/lib/qt5/qml/Sailfish/Silica/ApplicationWindow.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ApplicationWindow.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ApplicationWindow.qml
241-244 Timer... interval: 200 //600
261ff 2 x duration 133; //2 x 400 Take care of the ; after the number!
307 PauseAnimation { duration: 67 } //200
338 Behavior on xScale { NumberAnimation { id: xAnim; duration: 33 } } //100
339 Behavior on yScale { NumberAnimation { id: yAnim; duration: 33 } } //100
563 duration: 333 //1000
vi /usr/lib/qt5/qml/Sailfish/Silica/BusyLabel.qml
Undo:
vi /usr/lib/qt5/qml/Sailfish/Silica/BusyLabel.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/BusyLabel.qml
52 Behavior on opacity { FadeAnimator { duration: 10 } } // 400
vi /usr/lib/qt5/qml/Sailfish/Silica/ContextMenu.qml
Undo:
vi /usr/lib/qt5/qml/Sailfish/Silica/ContextMenu.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ContextMenu.qml
51 property int _openAnimationDuration: 10 //200
431 interval: 5 //10
453 interval: 5 //10
vi /usr/lib/qt5/qml/Sailfish/Silica/DatePicker.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/DatePicker.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/DatePicker.qml
281 interval: 11 //32
300 interval: 33 //100
vi /usr/lib/qt5/qml/Sailfish/Silica/DatePickerDialog.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/DatePickerDialog.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/DatePickerDialog.qml
116 duration: 167 // 500
123 duration: 167 // 500
289 duration: 100 // 300
296 duration: 100 // 300
vi /usr/lib/qt5/qml/Sailfish/Silica/Drawer.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/Drawer.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/Drawer.qml
72 duration: 10 // 300
139 duration: 10 // 300
vi /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSection.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSection.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSection.qml
58 readonly property int _animationDuration: _group ? _group.animationDuration : 10 // 200
vi /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSectionGroup.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSectionGroup.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSectionGroup.qml
56 property int animationDuration: 10 // 200
vi /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimation.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimation.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimation.qml
37 duration: 10 // 200
vi /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimator.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimator.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimator.qml
vi /usr/lib/qt5/qml/Sailfish/Silica/HorizontalScrollDecorator.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/HorizontalScrollDecorator.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/HorizontalScrollDecorator.qml
54 Behavior on opacity { FadeAnimation { duration: 13 } } // 400
70 interval: 10 // 300
vi /usr/lib/qt5/qml/Sailfish/Silica/ListItem.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ListItem.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ListItem.qml
98 duration: 10 // 200
vi /usr/lib/qt5/qml/Sailfish/Silica/MenuItem.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/MenuItem.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/MenuItem.qml
47 property int _duration: 17 //50
51 on_InvertColorsChanged: _duration = 67 //200
72 ScriptAction { script: _duration = 17 } //50
vi /usr/lib/qt5/qml/Sailfish/Silica/PageStack.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/PageStack.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/PageStack.qml
118 property int _transitionDuration: 100 // 400
620 FadeAnimation { duration: 100 } // 400
ab 668 ist jetzt einiges neu
1133 touchBlockTimer.interval = useAnimator ? _transitionDuration : Math.max(animation.duration - 20, 1) //50 ist ein Minuend! 20 geht!
1264 interval: 1 //1 Nix, lassen
1337 backgroundAnimation.duration = multiplier * 83 //250 Test new! Mary: 83 geht, nicht 63!
1347 duration: 50 // 100
1424 pageFadeIn.duration = multiplier * (differentOrientation ? 83 : 133) // 250 : 400 values should match line 1374 + line 592 OBSOLETE
1436 duration: 50 // 100
1443 duration: 83 // 250
1464 duration: 1000 // 1500
vi /usr/lib/qt5/qml/Sailfish/Silica/PulleyAnimationHint.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/PulleyAnimationHint.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/PulleyAnimationHint.qml
95 duration: 133*Math.max(1.0, pullDownDistance/Theme.itemSizeLarge) // 400
107 duration: 133 // Matches bounceback animation duration // 400
vi /usr/lib/qt5/qml/Sailfish/Silica/SilicaFlickable.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/SilicaFlickable.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/SilicaFlickable.qml
Line 63: maximumFlickVelocity: 2000 // was Theme.maximumFlickVelocity, quick and dirty for simply going faster.
vi /usr/lib/qt5/qml/Sailfish/Silica/Switch.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/Switch.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/Switch.qml
81 NumberAnimation { duration: busy ? 150 : 17; easing.type: Easing.InOutQuad } //450 : 50
88 NumberAnimation { duration: busy ? 150 : 17; easing.type: Easing.InOutQuad } //450 : 50
114 interval: 167 // 500
vi /usr/lib/qt5/qml/Sailfish/Silica/TapInteractionHint.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/TapInteractionHint.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/TapInteractionHint.qml
83 duration: 1500 // 2000
vi /usr/lib/qt5/qml/Sailfish/Silica/ValueButton.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ValueButton.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ValueButton.qml
52 property int _duration: 67 // 200
vi /usr/lib/qt5/qml/Sailfish/Silica/ViewPlaceholder.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ViewPlaceholder.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ViewPlaceholder.qml
70 Behavior on opacity { FadeAnimation { duration: 10 } } // 300
vi /usr/lib/qt5/qml/Sailfish/Silica/private/FastScrollAnimation.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/private/FastScrollAnimation.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/private/FastScrollAnimation.qml
Line 42: property real defaultDuration: 100 // 300
Line 118: velocity: 12000 //4000
Line 119: maximumEasingTime: 33 // 100
Line 125: velocity: 12000 //4000
Line 127: maximumEasingTime: 33 // 100
Line 164: PauseAnimation { duration: 80 } // 100
vi /usr/lib/qt5/qml/Sailfish/Silica/private/Slideable.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/private/Slideable.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/private/Slideable.qml
24 property int flickDuration: 100 //300
52 duration: 67 // 200
ok
284-342 mehrere Animations mit Variablen // einstweilen nix verändert, ist neu so
vi /usr/lib/qt5/qml/Sailfish/Silica/private/SliderBase.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/private/SliderBase.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/private/SliderBase.qml
93 duration: 100 // 300
104 duration: 100 // 300
vi /usr/lib/qt5/qml/Sailfish/Silica/private/ZoomableFlickable.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/private/ZoomableFlickable.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/private/ZoomableFlickable.qml
197 duration: 67 // 200
208 duration: 67 // 200
systemctl --user restart lipstick
vi /usr/lib/qt5/qml/Sailfish/WebView/WebView.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/WebView/WebView.qml.bak /usr/lib/qt5/qml/Sailfish/WebView/WebView.qml
194 duration: 35 //50 67 200
207 interval: 175 //250 333 1000
vi /usr/share/lipstick/simplecompositor/simplecompositor.qml
52 interval: 100 //1000
67 interval: 40 //400
Reduce unnecessary delays - Make it faster:
vi /usr/share/jolla-camera/camera.qml
Undo:
cp /usr/share/jolla-camera/camera.qml.bak /usr/share/jolla-camera/camera.qml
46 NumberAnimation { duration: 30; easing.type: Easing.InOutQuad } //150
Jolla-Notes:
vi /usr/share/jolla-notes/pages/NotePage.qml
Undo:
cp /usr/share/jolla-notes/pages/NotePage.qml.bak /usr/share/jolla-notes/pages/NotePage.qml
190 duration: 67 // 200
278 duration: 67 // 200
vi /usr/share/jolla-notes/pages/OverviewPage.qml
Undo:
cp /usr/share/jolla-notes/pages/OverviewPage.qml.bak /usr/share/jolla-notes/pages/OverviewPage.qml
4 x duration 600 -> 50 OK
169 PropertyAnimation { target: flashRect; property: "opacity"; to: Theme.opacityLow; duration: 30; easing.type: Easing.InOutQuad } //600
170 PropertyAnimation { target: flashRect; property: "opacity"; to: 0.01; duration: 30; easing.type: Easing.InOutQuad } //600
171 PropertyAnimation { target: flashRect; property: "opacity"; to: Theme.opacityLow; duration: 30; easing.type: Easing.InOutQuad } //600
172 PropertyAnimation { target: flashRect; property: "opacity"; to: 0.00; duration: 30; easing.type: Easing.InOutQuad } //600
// removes delay in 'Settings/DataCounter' until information become fully visible.
vi /usr/share/jolla-settings/pages/datacounters/mainpage.qml
Undo:
cp /usr/share/jolla-settings/pages/datacounters/mainpage.qml.bak /usr/share/jolla-settings/pages/datacounters/mainpage.qml
Line 127 // Behavior on height { enabled: pageReady; NumberAnimation { duration: 200; easing.type: Easing.InOutQuad } }
Comment out this line.
// removes delay in 'Settings/DeveloperOptions' until network settings become visible.
vi /usr/share/jolla-settings/pages/developermode/developermode.qml
Undo:
cp /usr/share/jolla-settings/pages/developermode/developermode.qml.bak /usr/share/jolla-settings/pages/developermode/developermode.qml
Line 503 - 506 Comment out this:
/* Behavior on height {
enabled: initialized
// removes delay in 'Settings/MobileNetwork' until information become fully visible.
vi /usr/share/jolla-settings/pages/mobile/mainpage.qml
Undo:
cp /usr/share/jolla-settings/pages/mobile/mainpage.qml.bak /usr/share/jolla-settings/pages/mobile/mainpage.qml
Line 108 // NumberAnimation { duration: 200; easing.type: Easing.InOutQuad }
vi /usr/share/jolla-startupwizard-pre-user-session/main.qml
Undo:
cp /usr/share/jolla-startupwizard-pre-user-session/main.qml.bak /usr/share/jolla-startupwizard-pre-user-session/main.qml
220 Behavior on opacity { FadeAnimation { duration: 10 } } //400
Undo:
cp /usr/share/lipstick/simplecompositor/simplecompositor.qml.bak /usr/share/lipstick/simplecompositor/simplecompositor.qml
67 interval: 40 // 400
vi /usr/share/lipstick-jolla-home-qt5/backgrounds/AmbienceBackgroundLoader.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/backgrounds/AmbienceBackgroundLoader.qml.bak /usr/share/lipstick-jolla-home-qt5/backgrounds/AmbienceBackgroundLoader.qml
55 duration: 10 // 800
Black background hack:
vi /usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml.bak /usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml
quick and easy test - open
/usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml,
and in line 10, where it says â0.65â, change it to â1ââŚ
Thanks very much @Levone1
vi /usr/share/lipstick-jolla-home-qt5/backgrounds/HomeWallpaperLoader.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/backgrounds/HomeWallpaperLoader.qml.bak /usr/share/lipstick-jolla-home-qt5/backgrounds/HomeWallpaperLoader.qml
39 duration: 10 // 800
Reduce unnecessary delays:
vi /usr/share/lipstick-jolla-home-qt5/compositor/ApplicationCloseGestureHint.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/compositor/ApplicationCloseGestureHint.qml.bak /usr/share/lipstick-jolla-home-qt5/compositor/ApplicationCloseGestureHint.qml
44 duration: 100 // 600
57 Behavior on opacity { FadeAnimator { duration: 100 } } // 600
70 Behavior on opacity { FadeAnimator { duration: 100 } } // 600
132 Behavior on opacity { FadeAnimator { duration: 100 } } // 600
vi /usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml.bak /usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml
44 transitionEnabled: true // true
51 transitionEnabled: true // true
52 transitionDelay: wallpaperItem.visible ? 67 : 0 // 200
85 duration: 67 // 200
95 Behavior on opacity { FadeAnimator { id: infoAnimation; duration: 100 } } // 300
vi /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml.bak /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml
Line 48 highlightMoveDuration: 100 // 300 // Match velocity with EdgeLayer transition's 300ms (0.3s below) duration 3 below -V
Line 123: duration: 67 // 200
vi /usr/share/lipstick-jolla-home-qt5/launcher/LauncherFolder.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/launcher/LauncherFolder.qml.bak /usr/share/lipstick-jolla-home-qt5/launcher/LauncherFolder.qml
46 Behavior on opacity { SmoothedAnimation { duration: 133; velocity: 1000 / duration } } // 400
260 Behavior on opacity { FadeAnimation { duration: 100 } } // 300
319 Behavior on y { NumberAnimation { duration: 100; easing.type: Easing.InOutQuad } } // 300
359 Behavior on opacity { FadeAnimation { duration: 100 } } //300 nicht auskommentieren!!
vi /usr/share/lipstick-jolla-home-qt5/launcher/LauncherGrid.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/launcher/LauncherGrid.qml.bak /usr/share/lipstick-jolla-home-qt5/launcher/LauncherGrid.qml
310 interval: 10 //200
vi /usr/share/lipstick-jolla-home-qt5/launcher/PinnedLauncherHint.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/launcher/PinnedLauncherHint.qml.bak /usr/share/lipstick-jolla-home-qt5/launcher/PinnedLauncherHint.qml
Line 35: Behavior on opacity { FadeAnimation { duration: 40 } } // 400
vi /usr/share/lipstick-jolla-home-qt5/layers/EdgeLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/EdgeLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/EdgeLayer.qml
in the middle, line 191 - 257, near transitions change all durations to abt. the half or 1/3 or 1/4.
200: 67 // 200
206: 67 // 200
222: 100 // 300 match all with 3 above (Launcher.qml)
228: 100 // 300 match all with 3 above (Launcher.qml)
248: 100 // 300 match all with 3 above (Launcher.qml)
255: 150 // 2000 Test 150, this can be much longer if wanted
260: 100 // 300 match all with 3 above (Launcher.qml)
------>> Match 100 from /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml match with 3 above
Remark: works good until now, looks good
vi /usr/share/lipstick-jolla-home-qt5/layers/HomeLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/HomeLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/HomeLayer.qml
43 duration: 10 //200
240 NumberAnimation { duration: 13; easing.type: Easing.OutQuad } // 250
Remove annoying hints on unlock: (the same fĂźr Sony und Volla)
vi /usr/share/lipstick-jolla-home-qt5/layers/LauncherLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/LauncherLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/LauncherLayer.qml
Change it at the end (Line 114) to say this:
edge: PeekFilter.Bottom
hintHeight: 0
hintDuration: 0
vi /usr/share/lipstick-jolla-home-qt5/layers/NotificationOverviewLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/NotificationOverviewLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/NotificationOverviewLayer.qml
Line 27: NumberAnimation { duration: 400; easing.type: Easing.OutQuad } // obscure! no change
Line 45: duration: 67 // 200
Line 149: duration: 133 // 400
Line 150: velocity: 1000 / duration // 1000 no change, velocity will increase automatically if duration is shorter
vi /usr/share/lipstick-jolla-home-qt5/layers/PartnerLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/PartnerLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/PartnerLayer.qml
126 interval: 167 // 500
234 duration: 100 // 300
249 duration: 100 // 300
257 duration: 100 // 300
407 duration: 133 // 400
vi /usr/share/lipstick-jolla-home-qt5/layers/StackLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/StackLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/StackLayer.qml
374 PauseAnimation { id: delayAnimation; duration: 50 } // 150
388 delayAnimation.duration = 50 // 150
398 duration: 100 // 300
vi /usr/share/lipstick-jolla-home-qt5/layers/TopMenuLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/TopMenuLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/TopMenuLayer.qml
30 hintDuration: 100 // 600
vi /usr/share/lipstick-jolla-home-qt5/lockscreen/DeviceLockView.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/lockscreen/DeviceLockView.qml.bak /usr/share/lipstick-jolla-home-qt5/lockscreen/DeviceLockView.qml
Check:
40 interval: 100 //300
Remove 2 arrows:
vi /usr/share/lipstick-jolla-home-qt5/lockscreen/EdgeIndicator.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/lockscreen/EdgeIndicator.qml.bak /usr/share/lipstick-jolla-home-qt5/lockscreen/EdgeIndicator.qml
Remove arrows left and right on unlock:
27 // source: "image://theme/graphics-edge-swipe-arrow"
Changing all 'duration:' parameters (e.g. 700 -> 35 ). changed to orig.value/20, eg. 700 -> 35
makes UI much faster. Valid only for this file + not for line 118 !
Test weil Werte links gehen nicht bei Mary's Handy - OK
107 40 // 400
115 70 // 700
116 velocity: 1000 / duration
119 150 // 1500
133 40 // 400
134 velocity: 1000 / duration
138 40 // 400
149 40 // 400
150 velocity: 1000 / duration
161 40 // 400
Restart lipstick:
Many thanks to @Edz !
vi /usr/share/lipstick-jolla-home-qt5/lockscreen/LockItem.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/lockscreen/LockItem.qml.bak /usr/share/lipstick-jolla-home-qt5/lockscreen/LockItem.qml
82 Behavior on opacity { FadeAnimation {} }
186 offsetAnimation.duration = 40 //400
188 opacityAnimation.duration = 40 //400
194 offsetAnimation.duration = 50 //500
196 opacityAnimation.duration = 50 //500
vi /usr/share/lipstick-jolla-home-qt5/lockscreen/Vignette.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/lockscreen/Vignette.qml.bak /usr/share/lipstick-jolla-home-qt5/lockscreen/Vignette.qml
26 duration: 100 //300
36 duration: vignette.opened ? 267 : 100 //800 : 300
44 duration: vignette.opened ? 267 : 100 //800 : 300
vi /usr/share/lipstick-jolla-home-qt5/main/OrientationTransition.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/main/OrientationTransition.qml.bak /usr/share/lipstick-jolla-home-qt5/main/OrientationTransition.qml
25 duration: 10 // 250
33 duration: 10 // 250
vi /usr/share/lipstick-jolla-home-qt5/main/PeekArea.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/main/PeekArea.qml.bak /usr/share/lipstick-jolla-home-qt5/main/PeekArea.qml
57 clipEndAnimation.duration = 100 // 600
92 SmoothedAnimation { id: opacityAnimation; duration: 100; velocity: 1000 / duration } // d=300, v=1000
152 clipEndAnimation.duration = 133 // 400
154 clipEndAnimation.duration = 67 // 200
164 clipEndAnimation.duration = 100 * (clipEndAnimation.to - peekFilter.absoluteProgress) / clipEndAnimation.to // 300
vi /usr/share/lipstick-jolla-home-qt5/switcher/CloseAllAppsHint.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/switcher/CloseAllAppsHint.qml.bak /usr/share/lipstick-jolla-home-qt5/switcher/CloseAllAppsHint.qml
13 interval: 167 // 500
26 Behavior on opacity { FadeAnimation { duration: 333 } } // 1000
vi /usr/share/lipstick-jolla-home-qt5/switcher/StartupWatcher.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/switcher/StartupWatcher.qml.bak /usr/share/lipstick-jolla-home-qt5/switcher/StartupWatcher.qml
14 interval: 50 // 2000, works fast 'n' good but screen flickers on app startup <--- hier ev raufsetzen weil Mary's Handy geht nicht 50
vi /usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml.bak /usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml
177 interval: 100 // no change
343 scrollAnimation.duration = 50 // 150
350 scrollAnimation.duration = 50 // 150
367 scrollAnimation.duration = Math.abs(contentY - scrollAnimation.to) * 1.5 // = works, save side! orig = 1.5
448 NumberAnimation { target: switcherItems; property: "opacity"; to: 0.0; duration: 67 } // 200
460 NumberAnimation { target: switcherItems; property: "opacity"; to: 1.0; duration: 67 } // 200
vi /usr/share/lipstick-jolla-home-qt5/switcher/SwitcherItem.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/switcher/SwitcherItem.qml.bak /usr/share/lipstick-jolla-home-qt5/switcher/SwitcherItem.qml
171 PauseAnimation { duration: 67 } // 200
174 duration: 133 // 400
223 PauseAnimation { duration: 83 } // 250
229 FadeAnimation { id: coverOpacityAnimation; duration: 167 } //500
240 Behavior on opacity { FadeAnimation { duration: 167 } } // 500
259 interval: coverHint && !coverId ? 1667 : 167 // 5000 : 500
277 ColorAnimation { duration: 33 } //100
282 NumberAnimation { duration: 50 } //50 ist wirklich so!
378 Behavior on opacity { FadeAnimation {} } //leer
406 Behavior on opacity { NumberAnimation { } } //leer
469 duration: 67 //200
476 duration: 67 //200
481 PauseAnimation { duration: 57 } //170
558 duration: 67 //200
vi /usr/share/lipstick-jolla-home-qt5/system/StartupScreenBlanker.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/system/StartupScreenBlanker.qml.bak /usr/share/lipstick-jolla-home-qt5/system/StartupScreenBlanker.qml
32 PauseAnimation { duration: 20 } // 400
vi /usr/share/lipstick-jolla-home-qt5/systemwindow/SystemWindow.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/systemwindow/SystemWindow.qml.bak /usr/share/lipstick-jolla-home-qt5/systemwindow/SystemWindow.qml
64 NumberAnimation { duration: 10; easing.type: Easing.InOutQuad } // 200
vi /usr/share/lipstick-jolla-home-qt5/topmenu/AmbienceSelector.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/topmenu/AmbienceSelector.qml.bak /usr/share/lipstick-jolla-home-qt5/topmenu/AmbienceSelector.qml
71 duration: 50 //500
79 NumberAnimation { property: "x"; duration: 50; easing.type: Easing.InOutQuad } // 500
158 Behavior on opacity { FadeAnimation {} } //nothing
212 NumberAnimation { properties: "y"; duration: 20 } // 200
vi /usr/share/lipstick-jolla-home-qt5/topmenu/TopMenu.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/topmenu/TopMenu.qml.bak /usr/share/lipstick-jolla-home-qt5/topmenu/TopMenu.qml
26 scrollAnimation.duration = Math.abs(contentY - scrollAnimation.to) * 1.5 //1.5
76 duration: 100 // 300
172 duration: 133 // 400
179 duration: 133 // 400
328 duration: Lipstick.compositor.powerKeyPressed ? scrollAnimation.duration : 67 // 200
460 duration: Lipstick.compositor.powerKeyPressed ? scrollAnimation.duration : 67 // 200
524 interval: 5000 // no change
Disable EU-audio volume warning:
vi /usr/share/lipstick-jolla-home-qt5/volumecontrol/VolumeControl.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/volumecontrol/VolumeControl.qml.bak /usr/share/lipstick-jolla-home-qt5/volumecontrol/VolumeControl.qml
STEPS: near line 564,
Change the following line (Line #564 in SFOS 5.0.0.61),
onShowAudioWarning: loader.showWarning(initial)
to:
onShowAudioWarning: volumeControl.setWarningAcknowledged(true)
Because this is within lipstick, we need to restart lipstick to take effect;
vi /usr/share/lipstick-jolla-home-qt5/windowwrappers/WindowWrapper.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/windowwrappers/WindowWrapper.qml.bak /usr/share/lipstick-jolla-home-qt5/windowwrappers/WindowWrapper.qml
35 FadeAnimator { duration: 10 } //600
vi /usr/share/lipstick-jolla-home-qt5/compositor.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/compositor.qml.bak /usr/share/lipstick-jolla-home-qt5/compositor.qml
234 property int pressDelay: 133 // 400
711 Behavior on opacity { FadeAnimator { duration: 100; alwaysRunToEnd: false } } // 300 & true
728 interval: 167 // 500
891 duration: 83 //250
945 extraGestureDuration: 167 //500
1163 Behavior on foregroundItem.opacity { FadeAnimator { duration: 100; alwaysRunToEnd: false } } // 300 & true
1171 interval: 1000 // 2000
1373 duration: 133 // 400
1860 interval: 83 // As short as possible without the end result looking unintentional //250
1867 interval: 2000 // no change
2073 interval: 1000 // no change
vi /usr/share/lipstick-jolla-home-qt5/main.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/main.qml.bak /usr/share/lipstick-jolla-home-qt5/main.qml
nix zu tun / checked, nothing to do
vi /usr/share/lipstick-obex-ui/main.qml
Undo:
cp /usr/share/lipstick-obex-ui/main.qml.bak /usr/share/lipstick-obex-ui/main.qml
52 interval: 133 // wait for window fade outs etc., // 400
vi /usr/share/lipstick-security-ui/PasswordAgentDialog.qml
Undo:
cp /usr/share/lipstick-security-ui/PasswordAgentDialog.qml.bak /usr/share/lipstick-security-ui/PasswordAgentDialog.qml
20 ? 50 // 1000
21 : 0
vi /usr/share/lipstick-security-ui/PasswordInputDialog.qml
Undo:
cp /usr/share/lipstick-security-ui/PasswordInputDialog.qml.bak /usr/share/lipstick-security-ui/PasswordInputDialog.qml
221 Behavior on y { NumberAnimation { duration: 67; easing.type: Easing.InOutQuad } } //200
vi /usr/share/lipstick-windowprompt/connectivity/ConnectionSelector.qml
Undo:
cp /usr/share/lipstick-windowprompt/connectivity/ConnectionSelector.qml.bak /usr/share/lipstick-windowprompt/connectivity/ConnectionSelector.qml
95 Behavior on keyboardHeight { NumberAnimation { duration: 67; easing.type: Easing.InOutQuad } } //200
414 Behavior on height { NumberAnimation { duration: 83; easing.type: Easing.InOutQuad } } //250
431 Behavior on height { NumberAnimation { duration: 83; easing.type: Easing.InOutQuad } } //250
950 interval: 167 //500
vi /usr/share/lipstick-windowprompt/main.qml
Undo:
cp /usr/share/lipstick-windowprompt/main.qml.bak /usr/share/lipstick-windowprompt/main.qml
47 _showTimer = singleShot(133, function() { // 400
61 singleShot(133, function() { // 400
vi /usr/share/lipstick-windowprompt/PermissionPrompt.qml
Undo.
cp /usr/share/lipstick-windowprompt/PermissionPrompt.qml.bak /usr/share/lipstick-windowprompt/PermissionPrompt.qml
121 Behavior on contentHeight { NumberAnimation { duration: 33; easing.type: Easing.InOutQuad } } //100
170 readonly property int visibleTime: 10 // 30
vi /usr/share/sailfish-office/FileListPage.qml
Undo:
cp /usr/share/sailfish-office/FileListPage.qml.bak /usr/share/sailfish-office/FileListPage.qml
105 duration: 30 // 150
133 Behavior on opacity { FadeAnimation { duration: 30 } } //150
--------------------------------------------- doppelt?
vi /usr/share/sailfish-archive/sailfish-archive.qml
Undo:
cp /usr/share/sailfish-archive/sailfish-archive.qml.bak /usr/share/sailfish-archive/sailfish-archive.qml
23 fade animation duration 100 //1000
vi /usr/share/sailfish-captiveportal/shared/OrientationFader.qml
Undo:
cp /usr/share/sailfish-captiveportal/shared/OrientationFader.qml.bak /usr/share/sailfish-captiveportal/shared/OrientationFader.qml
37 duration: 6 // 100
57 duration: 6 // 100
74 duration: 9 // 150
vi /usr/share/sailfish-captiveportal/shared/OverlayAnimator.qml
Undo:
cp /usr/share/sailfish-captiveportal/shared/OverlayAnimator.qml.bak /usr/share/sailfish-captiveportal/shared/OverlayAnimator.qml
42 property int proportionalDuration: 100 // 400
98 proportionalDuration = 150 * (1.0 - (infoHeight / webView.fullscreenHeight)) //600
100 proportionalDuration = 100 // 400
vi /usr/share/sailfish-captiveportal/shared/ProgressBar.qml
Undo:
cp /usr/share/sailfish-captiveportal/shared/ProgressBar.qml.bak /usr/share/sailfish-captiveportal/shared/ProgressBar.qml
34 velocity: 1440; duration: 67 //480; 200
----------------------------------------------------- ENDE neue Dateien
