Sony Xperia XZ1 Compact (lilac)
Hey,
I’m almost done porting sfOS 5.1 to lilac, and I’m wondering how and where could I distribute a community port image?
i did it on github under releases
Didn’t you do the port for Xperia X Compact?
This thread is about Xperia XZ1 Compact, which is different.
yes, i’m just answering your question. the question was where you can distribute the image and my answer was i uploaded it to github under releases, suggesting you could do it that way too. but you can do it however you want. i just wanted to help. have a nice day.
Sorry, it was my mistake, I didn’t see the original question.
oh and i didn’t see that you are a different person, i only percieved the color^^
I’m super interested in moving my xz1 compact from LineageOS to sailfish, so definitely let me know!
I’m also interested in beta testing. (:
Since I moved completely to my new JP26, I would also be interested in your lilac port.
Ah yes, this port came right after I sold my XZ1 Compact—what bad timing on my part! :rofl:
But i’m happy with my JP26 and C2 as a spare.
Any updates on topic?
It’s coming! Probably this week at some point
Here you go:
Thank You! Smooth install, no problems. Waiting for JP2026 phone, so I can use this phone to familiarize with SFOS. The only drawback in this phone is swollen battery.
RAM 4GB, 2.8GB free
storage 32GB, 17.7GB free
Finlayson 5.2.0.22
Nice! It is a 64Bit-Build of SailfishOS?
Yes. Some of the Sony blobs are 32bit, and for that there are some 32bit libraries
@p.virta Thank you for your work with this! I was able to get SailfishOS flashed and running on my non-global XZ1 Compact (The Docomo one)
For anyone wondering how, you first have to unlock its bootloader. There is a great guide here:
[GUIDE] Sony Xperia XZ1 Compact SO-02K (Docomo) – Bootloader Unlock via Xperable | TWRP & Custom ROMs
Follow it until you get to step 8. After that, you can stop there, and hop back over to p.virta’s guide. There are a few other issues however, to start, the recommended firmware (47.2.A.11.234) is for the global-only variant of these phones. Instead, I used SO-02K_47.2.B.5.38 sourced from the Internet Archive
After that, you can follow p.vitra’s steps to until you actually have to flash the device. the check will fail, as it is expecting the global version, so you have to change the listed device on line 13 of flash-config.sh with “SO-02K”
After that, it all works great!!
I thought unlocking the Japanese Docomo models wasn’t possible. Great that it works!
@p.virta
How well does the port work?
Does it support VoLTE?
Could someone make a video of usage?
To me that is a real danger not a drawback.
