Sony Xperia 10 V (A302SO)
Good morning everybody,
Could anyone confirm if the model of Sony 10 V mod A302SO (JAPAN VERSION) is compatible with the last Jolla OS 5 (named Tempella) ?
I would like to buy the license but I’m not sure if this device is fully supported.
What’s actually the best Xperia hardware running Sailfish smoothly ?
An opinion will be very appreciated.
Thank you to all the members of this forum
Marco
Nope. . . .
There is no license to buy at the moment for the Xperia 10V. As it is still in beta and not fully working.
You could try it, but we don’t know if it works. The Xperia 10V 8Gb version seems to work. So it could be possible. Be advised though that trying to do so could brick your phone if you don’t know what you are doing.
The flashing script might not work if it checks the model.
If that is the whole problem, that is trivial to fix. I.e. does not qualify as a real problem.
Lets hope the check is there for nothing :slight_smile:
Take care that A302SO may be carrier locked (Softbank)
only Japan XQ-DC44 is sell as “sim free” in Japan,
so if the phone wasn’t carrier unlocked possible unlock impossible.
Thank you for your information. The phone is unlocked but I’ve decided to return it to the seller.
I flash the Japanese XQ-DC44 to XQ-DC54 first, and then I can flash Sailfish OS
