Sony Xperia 10 iii
Android 13 is the recommened base to install Sailfish. Just use the official instructions and skip the downgrade to Android 11 part.
Sure, part of this is opinion and culture - but my main point is “imagine if everyone did like you”. It would be utter chaos in the forum.
And no; they would not simply read your thread - same as you did not read theirs.
That’s already available in the form the official instructions, which i’m sure you have already seen.
upgrade your phone to android13, and then follow the installation guide, including the part where it says to download the android11 v9a binaries from the guide. that being said, you CAN obtain the android12 v2a binaries, and they will work, but not necessarily better. the android13 binaries will not work.
I understand I’ll adopt this procedure thank you
