Sony Xperia 10 III SO-52B
Hello,
I wanted to have a spare phone in case my Jolla C2 failed, so I bought an Xperia 10 III at a good price.
I just received it and made the mistake of not asking the seller for the model name.
I received an Xperia 10 III with the reference number SO-52B and Android 13.
I have the impression that this is a phone intended for the Japanese market.
Do you know if it’s possible to install SFOS on this model?
Do you think the downgrading procedure is the same for going from Android 13 to 11?
Or should I just resell it?
it is not possible to install anything on this model, because the bootloader is not unlockable
At least it was like that for the same model I accidently purchased. You can check this in the service menue which is accessed by entering *#*#7378423#*#* in the phone app
Okay, thank you for your super quick reply.
