Sony Xperia 1 III XQ-BC52 & XQ-BC62 & XQ-BC72
IS there a difference between the 3 models above Xperia 1 III XQ-BC52/XQ-BC62/XQ-BC72 when it comes to install and utilize Sailfish OS?
I believe, respectively, they are for EU, US, Asia regions.
Here is the bands list:
Supported frequency bands
XQ-BC62
5GNR (Bands n1, n2, n3, n5, n7, n8, n20, n28, n38, n40, n41, n66, n71, n77,
n78), LTE (Bands 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 19, 20, 25, 26, 28, 29, 32, 34,
38, 39, 40, 41, 46, 48, 66, 71), UMTS HSPA+ (Bands 1, 2, 4, 5, 6, 8, 19), GSM
GPRS/EDGE (Bands 850, 900, 1 800, 1 900), Bluetooth (2.4GHz), WLAN
(2.4GHz/5GHz), NFC (13.56MHz), Wireless Power Charging (110-148kHz)
5GNR : 23dBm, LTE : 23dBm, UMTS : 24dBm, GSM 850/900 : 33dBm,
DCS(1 800)/PCS(1 900) : 30dBm, Bluetooth/WLAN (2.4GHz) : <100mW,
WLAN (5.15-5.35GHz, 5.47-5.725GHz) : <200mW, WLAN (5.735-5.835GHz) :
<25mW, NFC : < 42dBμA/m at 10m, Wireless Power Charging : < 42dBμA/m
at 10m
XQ-BC72
5GNR (Bands n1, n3, n5, n7, n8, n28, n38, n40, n41, n77, n78, n79), LTE (Bands
1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 19, 20, 25, 26, 28, 29, 34, 38, 39, 40, 41, 46, 66), UMTS
HSPA+ (Bands 1, 2, 4, 5, 6, 8, 19), GSM GPRS/EDGE (Bands 850, 900, 1 800,
1 900), Bluetooth (2.4GHz), WLAN (2.4GHz/5GHz), NFC (13.56MHz), Wireless
at 10m
[GB] For customers in countries/regions other than the United States and
Singapore:
The 5 150 - 5 350MHz band and the tethering mode (AP mode) in the 5GHz
band are restricted to indoor use only.
[GB] Supported frequency bands
Some frequency bands might be turned off in certain markets or by certain
operators.
You can find your model number under Settings > About phone
Xperia 1 models are not supported. Please search before posting.
For officially supported phones see here: https://shop.jolla.com
For exactly the model numbers supported by Jolla see here
If you are feeling adventurous see here for phones NOT supported by Jolla:
Thanks for this information! I mentioned your post here: Beta VoLTE on the Xperia 10 III, disabled by default - #85 by tao101
@AlanBreen liked it!
