Yes this one i know. But i had a huge Adrenalin rush putting sfos on it. And it runs really smooth and fast on that device. It’s a real charm
For me this does not matter, I always carry a mirrorless with me, never use a phone to take pictures.
I am so happy the V now runs sweet Sailfish instead of ugly and messy Android
Concerning the battery level, this was stated by the jolla team. It is a beta version.
Concerning the camera , this was stated by the jolla team. It is a beta version.
Yes i know both, but for the people that didn’t read thaw
I can remember to see a pull request with a ofono config. This commit blocked the second slot of Xperia 10V. It was necessary because of eSIM from european model. My version has two physical sim card slots. I will check it and probably we can activate the second card soon
or we will wait for an official image from Jolla
We all care so much about those.
I found only this part but I’m not sure that it will be user by ofono. I will look for others:
#FILE: /etc/appsupport.conf.d/30-hybris.conf
[Config]
Multisim=false
Thanks for working on this! I have the dual sim version of the 10 V waiting for a SFOS image. Great to see action.
Try:
nano /etc/ofono/binder.conf
[Settings]
ExpectSlots = slot1,slot2
[slot1]
path = /ril_0
slot = 0
[slot2]
path = /ril_1
slot = 1
devel-su systemctl restart ofono
Both sim cards are visible, but eSIM has no option to configure.
4 posts were split to a new topic: Problems with NextCloud
So long we still waiting for camera and other features is it any way to get android app support?
I don’t see any option on shop.jolla.com to buy a license.
There is only a legacy licence option.
Do any body knows more about it?
I think you have to wait for the final release that will not be a beta software. Time point depends on Sony and and availability of new blobs from Sony with working camera and hopefully adjusted non-crippled screen brightness.
If I understood correctly
And many other things depend on it.
Claim with this year availability of commercial images mentioned my rainemak doesn;t seem possible. I don’t work for Jolla, but even if new blobs are available, probably most of Jolla workers are sorting out mess with Jolla C2.
But Im waiting for 10 V as well as for my C2 to be repaired and would be very happy to play with em during christmas
I would really like to see how much can better software adaptation (C2) be versus significantly more powerful device (10 V)
My money would be on 10 V, but I would like to be suprised
As @paulvt menitoned here:
New builds from Sony are available to download ![]()
Could you please check for me if both SIM cards are able to register to VoLTE simultaneously? Not only the SIM that is set as default for mobile data connectivity? Thank you!
