[Solved]White screen after opening the camera at the lock screen
REPRODUCIBILITY (100%):
BUILD ID = 4.3.0.15 (Settings > About product):
HARDWARE (XA2):
UI LANGUAGE:
REGRESSION: (Yes):
Since I installed the 4.3.0.15 update when I open the camera from the lock screen I always get a blank white page.
Camera app to be opened.
White screen displayed.
I have had AdvancedCamera from openrepos installed. I removed it rebooted, but it did not helped.
To cure the slow camera startup introduced with the SailJail I tried to disable sandboxing in the
jolla-camera-lockscreen.desktop. I reverted those changes, rebooted, but still white image.
Are there any journalctrl commands to check the SailJail catches for e.g.?
Is this bug still present in 4.4.0.58?
I have not been dare enough to update my daily driver yet.
Not present on a flashed 4.4 XA2 here.
Upgrading to 4.4.058 solved this issue.
