It looks like you’re just missing a signalsEnabled: true statement inside the DBusInterfaace structure. There’s a decent explanation about handling signals in the sailfish dbus docs.
There can be other gotchas as well. For example, if the service drops in and out, you may have to set the watchServiceStatus property to true (it’s in the code, but not in the docs; I’m not sure why).
There must be something about this specific signal I’m generating. When I change it to e.g. the following, it works:
service: "uk.co.piggz.amazfish"
path: "/application"
iface: "uk.co.piggz.amazfish"
function informationChanged(a, b) {
console.log("1 informationChanged:", a, b);
Now I have to find the differences between the two signals…
I’m glad you made progress. Having been unhelpful before I’m a bit reticent about giving useless advice again, but just in case, the three things that spring to mind are datatype conversion, name mangling and name clashes.
If the datatype being passed via the signal is complex/unsupported, then I believe that can cause problems.
The name mangling code may change the case of the first letter.
Finally I think there can be name-clashes as well (e.g. if the signal matches one of the existing DBusInterface methods.
I haven’t used any exotic data types:
I’ve changed the code to closely resemble the one from amazfisch that does work but no progress yet,
despite the signals being almost identical:
works:
D-Bus
Header
Endianness Flag: l
Message Type: Signal emission (4)
Message Flags: 0x01
Protocol Version: 1
Message body Length: 14
Message Serial (cookie): 13931
Header fields Length: 110
Header Field: PATH
Field code: PATH (1)
Type signature: o
OBJECT_PATH: /application
Header Field: INTERFACE
Field code: INTERFACE (2)
Type signature: s
STRING: uk.co.piggz.amazfish
Header Field: MEMBER
Field code: MEMBER (3)
Type signature: s
STRING: informationChanged
Header Field: SIGNATURE
Field code: SIGNATURE (8)
Type signature: g
SIGNATURE: is
Header Field: SENDER
Field code: SENDER (7)
Type signature: s
STRING: :1.44
Body
INT32: 8
STRING: 17217
does not work:
D-Bus
Header
Endianness Flag: l
Message Flags: 0x01
Protocol Version: 1
Message body Length: 12
Message Serial (cookie): 46
Header fields Length: 111
Header Field: PATH
Type signature: o
Type signature: s
STRING: uk.co.piggz.amazfish2
Type signature: s
Type signature: g
SIGNATURE: is
Type signature: s
STRING: :1.446
Body
INT32: 43
STRING: xxx
Suspecting there may be something weird about the code in my initial program I’ve created one (from an example) in a completely different language to ensure it’s not something with the particular d-bus library I’m using.
Still no luck even in Python:
import dbus
import dbus.service
import dbus.mainloop.glib
import time
class TestObject(dbus.service.Object):
def __init__(self, conn, object_path='/application'):
dbus.service.Object.__init__(self, conn, object_path)
@dbus.service.signal('uk.co.piggz.amazfish2', signature='is')
def informationChanged(self, value, message):
pass
if __name__ == '__main__':
dbus.mainloop.glib.DBusGMainLoop(set_as_default=True)
session_bus = dbus.SessionBus()
name = dbus.service.BusName('uk.co.piggz.amazfish2', session_bus)
object = TestObject(session_bus)
while True:
time.sleep(1)
object.informationChanged(1, "test")
After comparing session bus traces over-and-over again I think I’ve found the issue.
It seems like having an error in the org.freedesktop.DBus.Introspectable method (or not having one as in the code snippet above) would prevent signals from being recognized by the QML interpreter. If I think about it It kind of makes sense if (at the start) it tries to match the function names in QML to signal names that may occur on the bus later.
