Snapchat on sailfish
Yep, it works if you first install the older versioned a little bit further up. After you have installed that, login and after that you can upgrade to the latest
It worked like a charm. Thank you!
How did that work for you? I’m trying to set it up for my younger brother but the old version doesn’t let us log in, it says the version is too old. Which version did you use exactly? Did you use the link from somewhere above in this topic?
