REPRODUCIBILITY: doesn’t work every time, after various restarts
OS VERSION: 4.5.0.18
HARDWARE: Sony xperia 10 III
UI LANGUAGE: English
REGRESSION: -
Sending SMS is responded with “couldn’t send message”. Receiving works, and also data transfer / phone.
none
on a new Sony xperia 10 III, try to send an SMS message (I assume this is not enough, but I have no other clues, unfortunately).
sending sms
not sending sms
none.
I have no other information.
The next time it appears, collect the logs following this tutorial .
thanks, I’ve gone through the procedure right now. What part of the logs can I post without worrying about privacy?
One additional thing: some people report similar problems with VoLTE – I haven’t switched that on manually, but I also don’t know if it is on or off: is there a way to see that?
emva
11 March 2023 15:18
5
It is a toggle button added to Settings → System → Mobile network → 4G calling (beta)
yes, it seems that I had this toggled “on”, and switching it off this made it work again. Thanks, saved my day!
karry
20 June 2024 20:26
7
I would not call it as solution, but workaround. We need VoLTE on majority of networks nowadays.
thx for the thread. Just had the same problem after flashing a xperia 10 iii.
Disabling like described by @emva seems to be working.
Still not really a solution - even 1 year later…
Louis
30 December 2024 23:27
9
I think this issue should be merged into this: [4.5.0.16] cannot send SMS when VoLTE enabled - #30 by Sturton
Check thread for a fix.
