Smartbanking for sailfish
Hmm. Maybe it’s a problem with MicroG then? As I need that for some other apps to function correctly, it would be problematic to decide whether to use it or not in favour of having the bank apps work. But I don’t know if that is the case. Probably the apps don’t work without MicroG installed either?
The apps complain about the device being rooted.
SecureGo Plus behaves like S-mobiili:
  • XA2 just hangs
  • 10 II opens the “rooted nag” webpage
  • Volla/GS290 with Waydroid works
I am not very skilled in Android things but I remember this was several times discussed on the forum.
If the search engine here doesn’t find, it jelps sometimes using e.g. Duckduckgo or google with
'your keywords' site:forum.sailfishos.org
It seems to be fixed with 4.4.0.68 now.
Do you have MicroG | Google Servicrs installed? Or does it also work without these services?
My banking app now works on 4.4.0.68 (without gapps / without microG)
