mairj
17 January 2023 22:32
1
Hi,
Since upgrade to 4.4.0.72 on Xperia 10 plus (Dual sim) i have problem calling from SIM1. On SIM1(Nederland number) on SIM2(Bulgarian number) so when trying to call from SIM1 numbers in only one out of 3 mobile provides in Bulgaria it is reporting out of coverage and call dismissed at the same time trying the same from SIM2 no issues. I tried all options i could think of going from 4g,3g,2g then stopping mobile data and wifi, then restarting phone no success at all make the call from SIM1. I opened case to NL provider KPN waiting their answer if it is something related to network as it was working before. Today I tested configuration of disabling SIM2 from setting , restart of the phone and finally all working perfectly with only SIM1 enabled.
Please let me know if there is some other fix I can try in order to have both sim’s working at the same time.
Thank you,
MairJ
mairj
18 January 2023 09:25
2
Update today again phone was restarted and with only SIM1 enable cannot call the numbers. So issue is not fixed.
mairj
19 January 2023 08:49
3
Here are the ofono logs when executing the call. I have been Sailor from Jolla 1 so if there is somebody that can help if that is bug or not.
– Logs begin at Thu 2023-01-19 09:36:37 CET. –
Jan 19 09:42:13 Sailfish ofonod[2896]: dialing “+359889******”
Jan 19 09:42:53 Sailfish ofonod[2896]: data reg changed 1 → 0 (unregistered), attached 0
Jan 19 09:42:54 Sailfish ofonod[2896]: data reg changed 0 → 1 (registered), attached 1
^C
[root@Sailfish nemo]# journalctl -b | grep -iE ‘(ofono|voicecall|telepathy)’
Jan 19 09:42:13 Sailfish telepathy-ring[5943]: trying to create call to “+359889******”
Jan 19 09:42:13 Sailfish telepathy-ring[5943]: call create request to “+359889******” successful
Jan 19 09:42:13 Sailfish [4914]: [D] unknown:0 - Type: “org.freedesktop.Telepathy.Channel.Type.StreamedMedia”
Jan 19 09:42:13 Sailfish [4914]: [D] unknown:0 - Interfaces: (“org.freedesktop.Telepathy.Channel.Interface.DTMF”, “org.freedesktop.Telepathy.Channel.Interface.Hold”, “org.freedesktop.Telepathy.Channel.Interface.Group”, “org.freedesktop.Telepathy.Channel.Interface.CallState”, “org.freedesktop.Telepathy.Channel.Interface.ServicePoint”, “org.freedesktop.Telepathy.Channel.Interface.Splittable.DRAFT”)
Jan 19 09:42:13 Sailfish lipstick[5092]: [D] onDestruction:268 - coverActionIndicators destroyed voicecall-ui.desktop
Jan 19 09:42:13 Sailfish lipstick[5092]: [D] onCompleted:264 - coverActionIndicators created voicecall-ui.desktop
Jan 19 09:42:32 Sailfish [4914]: [W] unknown:0 - void TelepathyProvider::onHandlerInvalidated(const QString&, const QString&) Handler invalidated: org.freedesktop.Telepathy.Error.Cancelled:
Jan 19 09:42:32 Sailfish [4914]: [D] unknown:0 - "Telepathy Handler Invalidated: org.freedesktop.Telepathy.Error.Cancelled - "
Jan 19 09:42:32 Sailfish voicecall-ui[5898]: [W] updateAction:229 - instance was empty
Jan 19 09:42:32 Sailfish voicecall-ui[5898]: [D] onError:555 - VoiceCallManager::onError Telepathy Handler Invalidated: org.freedesktop.Telepathy.Error.Cancelled -
Jan 19 09:42:32 Sailfish lipstick[5092]: [D] onDestruction:268 - coverActionIndicators destroyed voicecall-ui.desktop
Jan 19 09:42:32 Sailfish lipstick[5092]: [D] onCompleted:264 - coverActionIndicators created voicecall-ui.desktop
Jan 19 09:44:02 Sailfish estart[15899]: [W] unknown:36 - file:///usr/share/jolla-settings/pages/jolla-voicecall/CallSettings.qml:36: TypeError: Cannot read property of null
Jan 19 09:44:27 Sailfish estart[15899]: [D] unknown:0 - Retrying org.ofono.CallSettings.GetProperties “/ril_0”
Jan 19 09:44:27 Sailfish estart[15899]: [W] unknown:0 - QDBusError(“org.ofono.Error.InProgress”, “Operation already in progress”)
