OSVERSION: 5.0.0.43
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.30 - aarch64
REGRESSION: not specified
When entering the SIM PIN, the remaining attempt counter may be wrongly displaying too many remaining attempts.
See Steps, below.
- likely Patchmanager must be installed (?), at least one patch which causes a Lipstick restart enabled.
- SIM with PIN enabled
- Settings: “require PIN” enabled
- Boot device up to Lipstick Lock code prompt
- Enter Code
- SIM PIN prompt appears, showing 3 remainig attempts
- Enter wrong PIN two times
- Counter goes down to 1 remaining attempts
- Wait. Patchmanager will cause a Lipstick restart
- Enter Lock Code again
- Notice SIM PIN prompt does not appear
- Go to Settings->SIM
- Enter PIN again
- Notice prompt shows 3 remaining attempts.
EXPECTED RESULTS:
I expect the SIM to remember that there’s indeed only 1 attempt remaining.
If so, the UI should also.
ACTUAL RESULTS:
The displayed 3 remaining attempts are misleading.
- Patchmanager: yes
- OpenRepos: yes
- Chum: yes
- Other: none specified
This may be regarded as a Patchmanager defect. If so, fine.
It however will also appear if it is possible to dismiss the initial PIN dialog in another way than through the PM-initiated Lipstick restart.
Device Owner User: nemo
Home Encryption: enabled
