SIM not recognized on power on or restart on C2
OSVERSION: 5.0.0.29
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.15 - aarch64
UI LANGUAGE: Slovenščina (user: sl_SI, os: sl_SI.utf8)
REGRESSION: yes (since: 4.6.0.13 - n/a)
After each SFOS start I need to disable and reenable SIM. I have it slot identified as 1.
Operator Hot on A1 network
  1. Start SFOS
  2. SIM unkown so emergency calls only
  3. after disable, reenable SIM and entering SIM PIN network is registered
EXPECTED RESULTS:
On startup it asks for SIM PIN and network is available
ACTUAL RESULTS:
SFOS doesn’t even asks for SIM PIN.
  • Patchmanager: no
  • OpenRepos: yes
  • Chum: no
  • Other: none specified
Home Encryption: enabled
EDIT: No change in 5.0.0.29.
the initial version of this bug report was created using Bugger 0.9.10+git7
In my case it needs 5 Minutes for the first time after my O2-SIM-Card was recognized, after that no delays, even after reboot.
Maybe try Flightmode turn on and/or remove card and reinsert and/or reboot.
Flightmode and timeouts are unhelpful. Since I have a reliable and relatively simple workaround I’ll wait for a next release as there are more serious issues to solve.
I cannot even see any SIM card, be it placed in slot 1 or 2. Is there no way to force start the/a SIM related service ? If there is such a thing :slight_smile:
I think I get to see something similar. All of sudden, after a 3rd reboot, the SIM is recognised and works again. Phone calls function in 3G mode, both calling and receiving. SMSes aren’t though.
Or disable and reenable the SIM. I must do it on my SIM after every reboot.
Solved with 5.0.0.62!
Sadly not for me, maybe its dependent on the used carrier?
I have to perform this command after boot to get it working:
systemctl restart ofono
Same for me, still happening in 5.0.0.67 (i also do not have a PIN set, so it might try too early??)
