REPRODUCIBILITY:100% (always)
OS VERSION:5.2.0.20 (Finlayson)
HARDWARE: JOLLA PHONE 2026
UI LANGUAGE: ENGLISH
REGRESSION:
DESCRIPTION: After every reboot system is not recognizing sim card. in Sim cards setting it is showing sim card 1 and carrier name.
Mobile network setting: internet option is disabled or non clickable.
Use Sim Card: SIM1
SIM 1=Carrier Name showing
Roaming option: Enable/clickable
Data Access Point: Enable/clickable
MMS Access Point: Enable/clickable
Network Mode: Prefer 5G Enable/clickable
4G Calling VoLTE : Enable/clickable
Select Network Automatically is clickable too but keep searching.
Network option is non clickable stating Not Registered
Sim2= Unknown (as it is empty)
Top right of the screen it is showing two empty or not detected SIM Icon.
Restart SFOS 2026 Device
SIM unknown so emergency calls only
Try to make call but give error NO NETWORK COVERAGE
after disabling and enabling SIM again Network register and everything work again.
After system bootup network should detect and SIM services should work.
After system bootup no network detect or no SIM services work.
none specified
WIFI Work fine.
Using just one Sim Card
