REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.64
HARDWARE: Vollapone / GS290, 10ii (also .64).
UI LANGUAGE: EN
REGRESSION: not sure.
Given:
SilicaListView {
anchors.fill: parent
// (height and width don't matter)
Component.onCompleted: {
var time = new Date();
if (debug) console.debug(time.toTimeString(Locale.LongFormat).split(':')[0] )
tindex = time.toTimeString(Locale.LongFormat).split(':')[0]
// Does not work
listView.positionViewAtIndex(tindex, ListView.Beginning)
// Also not
positionViewAtEnd()
model: listModel
delegate: WeatherItem{
// Dosn't matter whether it on.
//VerticalScrollDecorator {flickable: listView}
It doesn’t seem possible to set the focus. Also tried setting the index.
Create and use SilicaListView.
- See the code above.
- Try to substitute a ListView. No diff.
Seting the index to position the view at should scroll view.
nothing. The onCompleted signal works. But position to index does not.
The number of elements (24) is always restricted to about 10 visible elements (device dependant).
Probably related? https://forum.sailfishos.org/t/silicalistview-positionviewatindex-from-contextmenu-buggy-behaviour
Also tested on a clean (don’t develop on, don’t hack in any way) sony 10ii (not yet .68, still .64). Must be me
